Date reverse?
SyRenity
Date reverse?
Post by SyRenity »
Hi.
I noticed, that for the last days, the date on images captured by ZM has been reversed - it went from dd/mm/yy to yy/mm/dd. I did not change any time settings on the system.
Probably it is a Christmas present from ZM? :)
jameswilson
Post by jameswilson »
mine have always been that way round but you can modify the timestamp to move them around
James Wilson
zoneminder
Site Admin
Post by zoneminder »
It is configurable in the monitor settings. Are you saying that setting has changed?
Phil
SyRenity
Post by SyRenity »
Hi.
Yes - frankly I didn't even knew there is such option. Even more - it changed in all the monitors I have.
Checking the timestamps, I can see indeed that it's have the following string: %%s - %y/%m/%d %H:%M:%S. Very curios.
zoneminder
Site Admin
This is the default but I don't know of any way that it could have been applied across the board without you knowing. (That's not to say there isn't a way!)
Phil
