Imediatly, with it being repeated untill I clicked OK on any one of the repeated windows. Will try the new versionjameswilson wrote:does it throw this immediately or after a period of time?
Aha... I think I killed CUPS so it doesnt load, I can try that now before bedjameswilson wrote:yeah please do as i dont know what this is. Im not sure how it will work on all distros as its only tested to work on redhat and suse.
It says you need
GTK+ 2.0 or higher
glibc-2.3 or higher
and CUPS for some reason (its a printing thing)
What distro you on and what spec of machine?
James
I agree once i have added this to the ms version i will add it to the linux version tooreduce CPU utilization - maxfps, using raw:)
option to run quad without rescalling images - will be much faster
agreedzoneminder image in the corner - to be fixed:)
I agree but i think i might have a settings file rather than a command line switch. The reason for the buttons at the top instead of full screen images is because ultimatly i want to run without a keyboard, ie mouse or touchscreen only. I might adda righht click event or a top right position opens menu kind idea though i will investigate the possibilties.command line arguments - not to show menu - when you only want to view cameras on cctv monitor without allowing person to change anything
How would you ideally like the cycle to work?cycle view
I always use images the same size - only local cameras without interlace 352x288 - so the quad without rescalling is almost ideal for screen resolution 800x600 - this one I use to output the screen to TV.Im not sure how much faster it would be, but i will look into this. Also it will be difficult to place the images unscaled as if you are using 2 cams as bttv cards, 1 640x480 ip cam nad a megapixel it wouldnt work. Plus im not sure how i caould code it to place the images equally regardless of desktop resolution. I will be changing the scaling soon to have anti-alaising and interpolation (like the ms one) but i need to read a lot more yet, as this isnt something suported by the ide yet.
Why not. Settings file is also good, but add command line option to specify which config file to use that will allow us to use simple "profiles".I agree but i think i might have a settings file rather than a command line switch. The reason for the buttons at the top instead of full screen images is because ultimatly i want to run without a keyboard, ie mouse or touchscreen only. I might adda righht click event or a top right position opens menu kind idea though i will investigate the possibilties.
Quad for 16 cameras changing four cameras every time. Or simple cycle single(fullscreen) with specified cameras.How would you ideally like the cycle to work?
I think that this raw format shouldn't be hard to implement. I'm not a programmer, so I couldn't get it working. Windows app IMHO shouldn't have raw option - it will be too much bandwidth inefficient, but if you have gigabit link to your zm, why not:)I agree the raw support is essential but is also new ground to me and this is my first ever linux app. If/once i see code /write code. that understands the images displaying them will be aesy. PLease note i havnt even looked at this yet, but will be soon as i plan to upgarde to 1.22 myslef in the next few days.
Im not sure i agree. I see what your saying that you always use a particular size but i for one dont. I aslo aim to get this to the tv out of the gfx card ultimatly. I think once we move to raw images the rescaling will not be an issue. I am not convinced on thios one,I always use images the same size - only local cameras without interlace 352x288 - so the quad without rescalling is almost ideal for screen resolution 800x600 - this one I use to output the screen to TV.
Placing should be set manually via config file in my opinion - this option should be intented to mount tv screens like these in shops not for normal use by people sitting next to computer.
I hope you now understand what is my goal.
True i like your thinking here. I will see if i can impliment command line switchesWhy not. Settings file is also good, but add command line option to specify which config file to use that will allow us to use simple "profiles".
I personally need raw support on the windows viewer so i will definetly be implimenting this lol. btw zm 1.22 is nothing to do with me, the god that is Phil is the one responsibleI think that this raw format shouldn't be hard to implement. I'm not a programmer, so I couldn't get it working. Windows app IMHO shouldn't have raw option - it will be too much bandwidth inefficient, but if you have gigabit link to your zm, why not:)
ps. 1.22 is great especially new event viewer.
Do as you are ideas, bug finding etc all needed as i dont have time to write these things and fully test them in the little spare time i actually have! lolPlease tell me how can I help you!
