Hi all and Phil,
Im starting to test 1.22 right today, and i would like to understand how can i use the raw streaming format.
i mena, mplayer can read it ? what is the command line arguments for zms ?
Thanks for now
Victor Diago
How im supposed to use Raw Streaming ?
- victor_diago
- Contact:
- zoneminder
- Site Admin
- Contact:
The raw streaming mode is not really meant for streaming to players like WMP. It was put in to reduce the overhead of streaming to James' gui viewers. That's not to say that it wouldn't work with any viewer that could handle the format but it's not a standard format supported by anything else as far as I'm aware.
Phil
- victor_diago
- Contact:
- zoneminder
- Site Admin
- Contact:
I will start work on this when i get round to upgrading my 'office' zm box to 1.22.x
James Wilson
- victor_diago
- Contact:
Yes it will be less cpu intensive but i doubt it will help the delay issues of mplayer as the delay is not due to zm, but the chosen media player. I plan to use it on zm4ms and the linux version.
James Wilson
- victor_diago
- Contact:
- zoneminder
- Site Admin
- Contact:
Raw streaming uses a lot more network bandwidth than other streams so if the lag was related to networking then it's only going to make it worse! However as jpeg streaming doesn't lag I think networking issues are not why plugins etc all lag.
The only real solution to the lagging is to get video streaming to use rtp and multicasting I think. Once I've done a bit more research into this I will try and add it.
Phil
