I'm on FC4, I don' t and I'm using a 4 port card. /dev/video0 (0-3). I only have channel 0 enabled, but I've tested all channels and all video inputs with the same results.
Video Blue with a timestamp in the upper left. This is with JPG or an mpeg stream.
I've checked the logs and nothing looks irregular since before the last successful install. var/log/messages seems fine too.
Monitor settings are:
/dev/video0
0
1
rgb24
320
240
Normal
Both monitor and source on the main page are orange, so at least this seems ok.
i turned debug on, but all the logs are jsut like this:
01/27/06 21:01:53.637710 zmu[4716].INF-zm_debug.c/304 [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.04716]
pci bus 0x0002 cardnum 0x0a function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
CardVendor 0x03ff card 0x0102 (Card unknown)
STATUS 0x0290 COMMAND 0x0106
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xf47fe008 addr 0xf47fe000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0b
# /usr/local/bin/zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
