At my wit's end here.. what am i doing wrong?
Been banging my head against this for hours, so I figured I'd ask those who would know best.
ZM 1.19.0 on Redhat 9
zmu -m 1 -U admin -P <XX> -q
Type : Remote
Host : netcam1.<fqdn>
Port : 80
Path : /axis-cgi/jpg/image.cgi?resolution=320x240 <-- (works fine from browser)
Width : 320
Height : 240
Palette : 4
Colours : 3
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 50
Warmup Count : 25
Pre Event Count : 10
Post Event Count : 10
Port : 80
Width : 320
Height : 240
Palette : 4
Colours : 3
Label Coord : 0,0
Warmup Count : 25
Section Length : 600
Maximum FPS : 0.00
Reference Blend %ge : 10
Function: 2 - Monitor
Zones : 1
Label : All
Type: 1 - Active
Limits : 0,0 - 319,239
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 2304
Max Alarm Pixels : 57600
Filter Box : 3,3
Min Filter Pixels : 2304
Max Filter Pixels : 57600
Min Blob Pixels : 1536
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
-- zmdc.log --
Starting pending process, zmc -m 1
'zmc -m 1' started at 04/03/19 03:42:17
'zmc -m 1' starting at 04/03/19 03:42:17, pid = 4250
Empty input file
'zmc -m 1' crashed at 04/03/19 03:42:18, exit status 1
-- strace zmc -m 1 --
execve("/usr/local/bin/zmc", ["zmc", "-m", "1"], [/* 19 vars */]) = 0
uname({sys="Linux", node="bdc.voicefx.com", ...}) = 0
brk(0) = 0xcaa2624
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40016000
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=27757, ...}) = 0
old_mmap(NULL, 27757, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40017000
close(3) = 0
open("/usr/lib/libmp3lame.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@e\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=363026, ...}) = 0
old_mmap(NULL, 710784, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4001e000
old_mmap(0x4006a000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4b000) = 0x4006a000
old_mmap(0x40070000, 374912, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40070000
close(3) = 0
open("/lib/libpcre.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240\n\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=36772, ...}) = 0
old_mmap(NULL, 39748, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x400cc000
old_mmap(0x400d5000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x8000) = 0x400d5000
close(3) = 0
open("/usr/lib/mysql/libmysqlclient.so.10", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\201\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=222464, ...}) = 0
old_mmap(NULL, 221824, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x400d6000
old_mmap(0x400f4000, 102400, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1e000) = 0x400f4000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\30"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=15900, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4010d000
old_mmap(NULL, 13176, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4010e000
old_mmap(0x40111000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0x40111000
close(3) = 0
open("/usr/lib/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260$\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=121028, ...}) = 0
old_mmap(NULL, 119908, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40112000
old_mmap(0x4012f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1d000) = 0x4012f000
close(3) = 0
open("/usr/lib/libstdc++.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\253\3"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=710608, ...}) = 0
old_mmap(NULL, 729660, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40130000
old_mmap(0x401d9000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xa9000) = 0x401d9000
old_mmap(0x401de000, 16956, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x401de000
close(3) = 0
open("/lib/tls/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2004\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=212020, ...}) = 0
old_mmap(NULL, 138496, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x401e3000
old_mmap(0x40204000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x40204000
close(3) = 0
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\10\23\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=30324, ...}) = 0
old_mmap(NULL, 29116, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40205000
old_mmap(0x4020c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x4020c000
close(3) = 0
open("/lib/tls/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220W\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1536292, ...}) = 0
old_mmap(0x42000000, 1261416, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x42000000
old_mmap(0x4212f000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x12f000) = 0x4212f000
old_mmap(0x42132000, 8040, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x42132000
close(3) = 0
open("/usr/lib/libz.so.1", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=60702, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4020d000
old_mmap(NULL, 55312, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4020e000
old_mmap(0x4021a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xb000) = 0x4021a000
close(3) = 0
open("/lib/libcrypt.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240\t\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=23688, ...}) = 0
old_mmap(NULL, 181312, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4021c000
old_mmap(0x40221000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0x40221000
old_mmap(0x40222000, 156736, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40222000
close(3) = 0
open("/lib/libnsl.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p<\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=91624, ...}) = 0
old_mmap(NULL, 85184, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40249000
old_mmap(0x4025b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x4025b000
old_mmap(0x4025c000, 7360, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4025c000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4025e000
mprotect(0x4001e000, 311296, PROT_READ|PROT_WRITE) = 0
mprotect(0x4001e000, 311296, PROT_READ|PROT_EXEC) = 0
set_thread_area({entry_number:-1 -> 6, base_addr:0x4025e5a0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
munmap(0x40017000, 27757) = 0
gettimeofday({1079685873, 220449}, {300, 0}) = 0
socket(PF_UNIX, SOCK_DGRAM, 0) = 3
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
connect(3, {sa_family=AF_UNIX, path="/dev/log"}, 16) = 0
getpid() = 4316
gettimeofday({1079685873, 221047}, {300, 0}) = 0
brk(0) = 0xcaa2624
brk(0xcaa3624) = 0xcaa3624
brk(0) = 0xcaa3624
brk(0xcaa4000) = 0xcaa4000
open("/etc/localtime", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=1267, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
read(4, "TZif\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\4\0\0\0\4\0"..., 4096) = 1267
close(4) = 0
munmap(0x40017000, 4096) = 0
brk(0) = 0xcaa4000
brk(0xcaa5000) = 0xcaa5000
time([1079685873]) = 1079685873
getpid() = 4316
rt_sigaction(SIGPIPE, {0x420db0d0, [], SA_RESTORER, 0x420276f8}, {SIG_DFL}, 8) = 0
send(3, "<142>Mar 19 03:44:33 zmc-m1[4316"..., 70, 0) = 70
rt_sigaction(SIGPIPE, {SIG_DFL}, NULL, 8) = 0
rt_sigaction(SIGUSR1, {0x805c638, [ABRT 33 35 36 37 38 41 42 45 47 51 58 63], SA_RESTORER|SA_RESTART, 0x420276f8}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGUSR2, {0x805c638, [ABRT 33 35 36 37 38 41 42 45 47 51 58 63], SA_RESTORER|SA_RESTART, 0x420276f8}, {SIG_DFL}, 8) = 0
open("/etc/nsswitch.conf", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=1863, ...}) = 0
read(4, "#\n# /etc/nsswitch.conf\n#\n# An ex"..., 4096) = 1863
read(4, "", 4096) = 0
close(4) = 0
open("/etc/ld.so.cache", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=27757, ...}) = 0
old_mmap(NULL, 27757, PROT_READ, MAP_PRIVATE, 4, 0) = 0x40017000
close(4) = 0
open("/lib/libnss_files.so.2", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\35\0"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0755, st_size=52492, ...}) = 0
old_mmap(NULL, 47068, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4025f000
old_mmap(0x4026a000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xa000) = 0x4026a000
close(4) = 0
open("/etc/services", O_RDONLY) = 4
fcntl64(4, F_GETFD) = 0
fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
fstat64(4, {st_mode=S_IFREG|0644, st_size=19935, ...}) = 0
read(4, "# /etc/services:\n# $Id: services"..., 4096) = 4096
read(4, "BIOS Name Service\nnetbios-ns\t137"..., 4096) = 4096
read(4, "cs\t\t994/udp\npop3s\t\t995/tcp\t\t\t\t# "..., 4096) = 4096
read(4, "de effect\ncodasrv\t\t2432/tcp\t\t\t# "..., 4096) = 4096
close(4) = 0
rt_sigaction(SIGPIPE, {SIG_IGN}, {SIG_DFL}, 8) = 0
socket(PF_UNIX, SOCK_STREAM, 0) = 4
fcntl64(4, F_GETFL) = 0x2 (flags O_RDWR)
connect(4, {sa_family=AF_UNIX, path="/var/lib/mysql/mysql.sock"}, 110) = 0
brk(0) = 0xcaa5000
brk(0xcaa6000) = 0xcaa6000
setsockopt(4, SOL_IP, IP_TOS, [8], 4) = -1 EOPNOTSUPP (Operation not supported)
setsockopt(4, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0
read(4, "(\0\0\0", 4) = 4
read(4, "\n3.23.54\0\200\0\0\0xIBPKgGh\0,\0\10\2\0\0\0\0\0\0"..., 40) = 40
open("/usr/share/mysql/charsets/Index", O_RDONLY|O_LARGEFILE) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=549, ...}) = 0
read(5, "# sql/share/charsets/Index\n#\n# T"..., 4096) = 549
brk(0) = 0xcaa6000
brk(0xcaa7000) = 0xcaa7000
read(5, "", 4096) = 0
close(5) = 0
write(4, "\22\0\0\1\205 \0\0\0root\0IBA^EAMU", 22) = 22
read(4, "\3\0\0\2", 4) = 4
read(4, "\0\0\0", 3) = 3
fcntl64(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
read(4, 0xcaa3a30, 8192) = -1 EAGAIN (Resource temporarily unavailable)
fcntl64(4, F_SETFL, O_RDWR) = 0
write(4, "\3\0\0\0\2zm", 7) = 7
read(4, "\3\0\0\1", 4) = 4
write(4, "-\1\0\0\3select Id, Name, Type, Func"..., 305) = 305
read(4, "\1\0\0\1", 4) = 4
read(4, "\32", 1) = 1
read(4, "\26\0\0\2", 4) = 4
read(4, "\10Monitors\2Id\3\n\0\0\1\3\3#B\0", 22) = 22
brk(0) = 0xcaa7000
brk(0xcaa9000) = 0xcaa9000
read(4, "\30\0\0\3", 4) = 4
read(4, "\10Monitors\4Name\3\377\0\0\1\374\3\21\0\0", 24) = 24
read(4, "\30\0\0\4", 4) = 4
read(4, "\10Monitors\4Type\3\6\0\0\1\376\3\1\1\0", 24) = 24
read(4, "\26\0\0\5", 4) = 4
read(4, "\0\nFunction+0\3\27\0\0\1\5\3\1\0\37", 22) = 22
read(4, "\32\0\0\6", 4) = 4
read(4, "\10Monitors\6Device\3\3\0\0\1\1\3!\0\0", 26) = 26
read(4, "\33\0\0\7", 4) = 4
read(4, "\10Monitors\7Channel\3\3\0\0\1\1\3!\0\0", 27) = 27
read(4, "\32\0\0\10", 4) = 4
read(4, "\10Monitors\6Format\3\3\0\0\1\1\3!\0\0", 26) = 26
read(4, "\30\0\0\t", 4) = 4
read(4, "\10Monitors\4Host\3@\0\0\1\375\3\0\0\0", 24) = 24
read(4, "\30\0\0\n", 4) = 4
read(4, "\10Monitors\4Port\3\10\0\0\1\375\3\0\0\0", 24) = 24
read(4, "\30\0\0\v", 4) = 4
read(4, "\10Monitors\4Path\3\377\0\0\1\375\3\0\0\0", 24) = 24
read(4, "\31\0\0\f", 4) = 4
read(4, "\10Monitors\5Width\3\5\0\0\1\2\3!\0\0", 25) = 25
read(4, "\32\0\0\r", 4) = 4
read(4, "\10Monitors\6Height\3\5\0\0\1\2\3!\0\0", 26) = 26
read(4, "\33\0\0\16", 4) = 4
read(4, "\10Monitors\7Palette\3\3\0\0\1\1\3!\0\0", 27) = 27
read(4, "\31\0\0\17", 4) = 4
read(4, "\0\rOrientation+0\3\27\0\0\1\5\3\1\0\37", 25) = 25
read(4, "\37\0\0\20", 4) = 4
read(4, "\10Monitors\vLabelFormat\3 \0\0\1\375\3\1\0\0", 31) = 31
read(4, "\32\0\0\21", 4) = 4
read(4, "\10Monitors\6LabelX\3\5\0\0\1\2\3 \0\0", 26) = 26
read(4, "\32\0\0\22", 4) = 4
read(4, "\10Monitors\6LabelY\3\5\0\0\1\2\3 \0\0", 26) = 26
read(4, "$\0\0\23", 4) = 4
read(4, "\10Monitors\20ImageBufferCount\3\5\0\0\1\2"..., 36) = 36
read(4, "\37\0\0\24", 4) = 4
read(4, "\10Monitors\vWarmupCount\3\5\0\0\1\2\3!\0\0", 31) = 31
read(4, "!\0\0\25", 4) = 4
read(4, "\10Monitors\rPreEventCount\3\5\0\0\1\2\3!\0"..., 33) = 33
read(4, "\"\0\0\26", 4) = 4
read(4, "\10Monitors\16PostEventCount\3\5\0\0\1\2\3!"..., 34) = 34
read(4, "!\0\0\27", 4) = 4
read(4, "\10Monitors\rSectionLength\3\n\0\0\1\3\3!\0"..., 33) = 33
read(4, "\35\0\0\30", 4) = 4
read(4, "\10Monitors\tFrameSkip\3\5\0\0\1\2\3!\0\0", 29) = 29
read(4, "\32\0\0\31", 4) = 4
read(4, "\10Monitors\6MaxFPS\3\7\0\0\1\0\3\1\0\2", 26) = 26
read(4, "%\0\0\32", 4) = 4
read(4, "\10Monitors\21FPSReportInterval\3\5\0\0\1"..., 37) = 37
read(4, " \0\0\33", 4) = 4
read(4, "\10Monitors\fRefBlendPerc\3\3\0\0\1\1\3!\0\0", 32) = 32
read(4, "\1\0\0\34", 4) = 4
read(4, "\376", 1) = 1
brk(0) = 0xcaa9000
brk(0xcaab000) = 0xcaab000
read(4, "\242\0\0\35", 4) = 4
read(4, "\0011\7Netcam1\6Remote\0012\0010\0010\0010\23netcam"..., 162) = 162
read(4, "\1\0\0\36", 4) = 4
write(4, "1\0\0\0\3select Name, Value, Type fr"..., 53) = 53
read(4, "\3", 1) = 1
read(4, "\6Config\4Name\3 \0\0\1\375\3\7@\0", 22) = 22
brk(0) = 0xcaab000
brk(0xcaad000) = 0xcaad000
read(4, "\27\0\0\3", 4) = 4
read(4, "\6Config\5Value\3\377\377\0\1\374\3\21\0\0", 23) = 23
read(4, "\26\0\0\4", 4) = 4
read(4, "\6Config\4Type\3\377\0\0\1\374\3\21\0\0", 22) = 22
read(4, "\1\0\0\5", 4) = 4
brk(0) = 0xcaad000
brk(0xcaaf000) = 0xcaaf000
read(4, "\17ZM_LANG_DEFAULT\2en\6string", 26) = 26
read(4, "\32\0\0\7", 4) = 4
read(4, "\17ZM_OPT_USE_AUTH\0011\7boolean", 26) = 26
read(4, "\34\0\0\10", 4) = 4
read(4, "\rZM_DIR_EVENTS\6events\6string", 28) = 28
read(4, "\34\0\0\t", 4) = 4
read(4, "\rZM_DIR_IMAGES\6images\6string", 28) = 28
read(4, "\34\0\0\n", 4) = 4
read(4, "\rZM_DIR_SOUNDS\6sounds\6string", 28) = 28
read(4, " \0\0\v", 4) = 4
read(4, "\vZM_PATH_ZMS\f/cgi-bin/zms\6string", 32) = 32
read(4, "\32\0\0\f", 4) = 4
read(4, "\rZM_CAN_STREAM\4auto\6string", 26) = 26
read(4, "\33\0\0\r", 4) = 4
read(4, "\20ZM_OPT_CAMBOZOLA\0010\7boolean", 27) = 27
read(4, "\'\0\0\16", 4) = 4
read(4, "\21ZM_PATH_CAMBOZOLA\rcambozola.jar"..., 39) = 39
read(4, "\"\0\0\17", 4) = 4
read(4, "\27ZM_TIMESTAMP_ON_CAPTURE\0011\7boole"..., 34) = 34
read(4, "\36\0\0\20", 4) = 4
read(4, "\23ZM_LOCAL_BGR_INVERT\0011\7boolean", 30) = 30
read(4, "\34\0\0\21", 4) = 4
read(4, "\21ZM_Y_IMAGE_DELTAS\0011\7boolean", 28) = 28
read(4, "\37\0\0\22", 4) = 4
read(4, "\24ZM_FAST_IMAGE_BLENDS\0011\7boolean", 31) = 31
read(4, "\37\0\0\23", 4) = 4
read(4, "\24ZM_COLOUR_JPEG_FILES\0011\7boolean", 31) = 31
read(4, " \0\0\24", 4) = 4
read(4, "\24ZM_JPEG_FILE_QUALITY\00270\7integer", 32) = 32
read(4, "\25ZM_JPEG_IMAGE_QUALITY\00270\7intege"..., 33) = 33
read(4, "\27ZM_BLEND_ALARMED_IMAGES\0011\7boole"..., 34) = 34
read(4, "\26ZM_NO_MAX_FPS_ON_ALARM\0011\7boolea"..., 33) = 33
read(4, "\37\0\0\30", 4) = 4
read(4, "\24ZM_OPT_ADAPTIVE_SKIP\0011\7boolean", 31) = 31
read(4, " \0\0\31", 4) = 4
read(4, "\25ZM_OPT_REMOTE_CAMERAS\0011\7boolean", 32) = 32
read(4, "\33\0\0\32", 4) = 4
read(4, "\17ZM_HTTP_VERSION\0031.1\6string", 27) = 27
read(4, "\23\0\0\33", 4) = 4
read(4, "\nZM_HTTP_UA\0\6string", 19) = 19
read(4, "\35\0\0\34", 4) = 4
read(4, "\17ZM_HTTP_TIMEOUT\0042500\7integer", 29) = 29
read(4, "\26\0\0\35", 4) = 4
read(4, "\vZM_OPT_MPEG\2no\6string", 22) = 22
read(4, "6\0\0\36", 4) = 4
read(4, "\23ZM_PATH_MPEG_ENCODE\32/usr/local/"..., 54) = 54
read(4, "&\0\0\37", 4) = 4
read(4, "\16ZM_PATH_FFMPEG\17/usr/bin/ffmpeg\6"..., 38) = 38
read(4, "$\0\0 ", 4) = 4
read(4, "\21ZM_FFMPEG_OPTIONS\n-hq -intra\6st"..., 36) = 36
read(4, "\30\0\0!", 4) = 4
read(4, "\rZM_OPT_NETPBM\0011\7boolean", 24) = 24
read(4, "\37\0\0\"", 4) = 4
read(4, "\16ZM_PATH_NETPBM\10/usr/bin\6string", 31) = 31
read(4, "\32\0\0#", 4) = 4
read(4, "\rZM_PATH_SOCKS\4/tmp\6string", 26) = 26
read(4, "\31\0\0$", 4) = 4
read(4, "\fZM_PATH_LOGS\4/tmp\6string", 25) = 25
read(4, "#\0\0%", 4) = 4
read(4, "\26ZM_VIDEO_STREAM_METHOD\4mpeg\6str"..., 35) = 35
read(4, " \0\0&", 4) = 4
read(4, "\25ZM_VIDEO_TIMED_FRAMES\0011\7boolean", 32) = 32
read(4, " \0\0\'", 4) = 4
read(4, "\24ZM_VIDEO_LIVE_FORMAT\3asf\6string", 32) = 32
read(4, "\"\0\0(", 4) = 4
read(4, "\26ZM_VIDEO_REPLAY_FORMAT\3asf\6stri"..., 34) = 34
read(4, "!\0\0)", 4) = 4
read(4, "\24ZM_WEB_DEFAULT_SCALE\003100\7intege"..., 33) = 33
read(4, " \0\0*", 4) = 4
read(4, "\23ZM_WEB_DEFAULT_RATE\003100\7integer", 32) = 32
read(4, " \0\0+", 4) = 4
read(4, "\25ZM_WEB_POPUP_ON_ALARM\0011\7boolean", 32) = 32
read(4, "\25\0\0,", 4) = 4
read(4, "\nZM_OPT_X10\0010\7boolean", 21) = 21
read(4, " \0\0-", 4) = 4
read(4, "\rZM_X10_DEVICE\n/dev/ttyS0\6string", 32) = 32
read(4, "\33\0\0.", 4) = 4
read(4, "\21ZM_X10_HOUSE_CODE\1A\6string", 27) = 27
read(4, "%\0\0/", 4) = 4
read(4, "\31ZM_X10_DB_RELOAD_INTERVAL\00260\7in"..., 37) = 37
read(4, " \0\0000", 4) = 4
read(4, "\25ZM_WEB_SOUND_ON_ALARM\0011\7boolean", 32) = 32
read(4, " \0\0001", 4) = 4
read(4, "\22ZM_WEB_ALARM_SOUND\5sound\6string", 32) = 32
read(4, "\"\0\0002", 4) = 4
read(4, "\27ZM_WEB_MONTAGE_MAX_COLS\0012\7integ"..., 34) = 34
read(4, "\37\0\0003", 4) = 4
read(4, "\24ZM_WEB_MONTAGE_WIDTH\0010\7integer", 31) = 31
read(4, " \0\0004", 4) = 4
read(4, "\25ZM_WEB_MONTAGE_HEIGHT\0010\7integer", 32) = 32
read(4, "\35\0\0005", 4) = 4
read(4, "\22ZM_OPT_FAST_DELETE\0011\7boolean", 29) = 29
read(4, "!\0\0006", 4) = 4
read(4, "\26ZM_STRICT_VIDEO_CONFIG\0010\7boolea"..., 33) = 33
read(4, "\"\0\0007", 4) = 4
read(4, "\nZM_SHM_KEY\n0x7a6d2000\vhexadecim"..., 34) = 34
read(4, "#\0\0008", 4) = 4
read(4, "\26ZM_FILTER_RELOAD_DELAY\003300\7inte"..., 35) = 35
read(4, "\30\0\0009", 4) = 4
read(4, "\rZM_OPT_UPLOAD\0010\7boolean", 24) = 24
read(4, "!\0\0:", 4) = 4
read(4, "\25ZM_UPLOAD_ARCH_FORMAT\3tar\6strin"..., 33) = 33
read(4, "\"\0\0;", 4) = 4
read(4, "\27ZM_UPLOAD_ARCH_COMPRESS\0010\7boole"..., 34) = 34
read(4, "!\0\0<", 4) = 4
read(4, "\26ZM_UPLOAD_ARCH_ANALYSE\0010\7boolea"..., 33) = 33
read(4, "\33\0\0=", 4) = 4
read(4, "\22ZM_UPLOAD_FTP_HOST\0\6string", 27) = 27
read(4, "\33\0\0>", 4) = 4
read(4, "\22ZM_UPLOAD_FTP_USER\0\6string", 27) = 27
read(4, "\33\0\0?", 4) = 4
read(4, "\22ZM_UPLOAD_FTP_PASS\0\6string", 27) = 27
read(4, "\"\0\0@", 4) = 4
read(4, "\25ZM_UPLOAD_FTP_LOC_DIR\4/tmp\6stri"..., 34) = 34
read(4, "\36\0\0A", 4) = 4
read(4, "\25ZM_UPLOAD_FTP_REM_DIR\0\6string", 30) = 30
read(4, "\"\0\0B", 4) = 4
read(4, "\25ZM_UPLOAD_FTP_TIMEOUT\003120\7integ"..., 34) = 34
read(4, " \0\0C", 4) = 4
read(4, "\25ZM_UPLOAD_FTP_PASSIVE\0011\7boolean", 32) = 32
read(4, "\36\0\0D", 4) = 4
read(4, "\23ZM_UPLOAD_FTP_DEBUG\0011\7boolean", 30) = 30
read(4, "\27\0\0E", 4) = 4
read(4, "\fZM_OPT_EMAIL\0011\7boolean", 23) = 23
read(4, ")\0\0F", 4) = 4
read(4, "\20ZM_EMAIL_ADDRESS\20tech@voicefx.c"..., 41) = 41
read(4, "\31\r\0G", 4) = 4
read(4, "\rZM_EMAIL_TEXT\374\3\r#\n# This is the"..., 3353) = 3353
read(4, "\31\0\0H", 4) = 4
read(4, "\16ZM_OPT_MESSAGE\0011\7boolean", 25) = 25
read(4, ",\0\0I", 4) = 4
read(4, "\22ZM_MESSAGE_ADDRESS\21tech@voicefx"..., 44) = 44
read(4, ":\7\0J", 4) = 4
read(4, "\17ZM_MESSAGE_TEXT\374\"\7# \n# This is "..., 1850) = 1850
brk(0) = 0xcaaf000
brk(0xcab1000) = 0xcab1000
read(4, "\34\0\0K", 4) = 4
read(4, "\17ZM_EMAIL_METHOD\4smtp\6string", 28) = 28
read(4, "\"\0\0L", 4) = 4
read(4, "\rZM_EMAIL_HOST\f10.10.10.132\6stri"..., 34) = 34
read(4, "\'\0\0M", 4) = 4
read(4, "\rZM_FROM_EMAIL\21tech@voicefx.com "..., 39) = 39
read(4, ")\0\0N", 4) = 4
read(4, "\6ZM_URL\32http://cameras.voicefx.c"..., 41) = 41
read(4, "#\0\0O", 4) = 4
read(4, "\27ZM_WATCH_CHECK_INTERVAL\00210\7inte"..., 35) = 35
read(4, "\36\0\0P", 4) = 4
read(4, "\22ZM_WATCH_MAX_DELAY\00215\7decimal", 30) = 30
read(4, "\"\0\0Q", 4) = 4
read(4, "\25ZM_FORCED_ALARM_SCORE\003255\7integ"..., 34) = 34
read(4, "#\0\0R", 4) = 4
read(4, "\26ZM_BULK_FRAME_INTERVAL\003100\7inte"..., 35) = 35
read(4, " \0\0S", 4) = 4
read(4, "\25ZM_RECORD_EVENT_STATS\0011\7boolean", 32) = 32
read(4, " \0\0T", 4) = 4
read(4, "\25ZM_RECORD_DIAG_IMAGES\0010\7boolean", 32) = 32
read(4, "$\0\0U", 4) = 4
read(4, "\31ZM_CREATE_ANALYSIS_IMAGES\0011\7boo"..., 36) = 36
read(4, "\36\0\0V", 4) = 4
read(4, "\23ZM_OPT_FRAME_SERVER\0010\7boolean", 30) = 30
read(4, "\37\0\0W", 4) = 4
read(4, "\24ZM_FRAME_SOCKET_SIZE\0010\7integer", 31) = 31
read(4, "\37\0\0X", 4) = 4
read(4, "\24ZM_CHECK_FOR_UPDATES\0011\7boolean", 31) = 31
read(4, "(\0\0Y", 4) = 4
read(4, "\25ZM_WEB_REFRESH_METHOD\njavascrip"..., 40) = 40
read(4, "\37\0\0Z", 4) = 4
read(4, "\24ZM_WEB_DOUBLE_BUFFER\0011\7boolean", 31) = 31
read(4, "!\0\0[", 4) = 4
read(4, "\26ZM_WEB_COMPACT_MONTAGE\0010\7boolea"..., 33) = 33
read(4, "\"\0\0\\", 4) = 4
read(4, "\25ZM_WEB_H_REFRESH_MAIN\003300\7integ"..., 34) = 34
read(4, "\"\0\0]", 4) = 4
read(4, "\26ZM_WEB_H_REFRESH_CYCLE\00210\7integ"..., 34) = 34
read(4, "!\0\0^", 4) = 4
read(4, "\26ZM_WEB_H_REFRESH_IMAGE\0015\7intege"..., 33) = 33
read(4, "\"\0\0_", 4) = 4
read(4, "\27ZM_WEB_H_REFRESH_STATUS\0013\7integ"..., 34) = 34
read(4, "#\0\0`", 4) = 4
read(4, "\27ZM_WEB_H_REFRESH_EVENTS\00230\7inte"..., 35) = 35
read(4, "&\0\0a", 4) = 4
read(4, "\26ZM_WEB_H_VIDEO_BITRATE\006150000\7i"..., 38) = 38
read(4, "!\0\0b", 4) = 4
read(4, "\25ZM_WEB_H_VIDEO_MAXFPS\00215\7intege"..., 33) = 33
read(4, "!\0\0c", 4) = 4
read(4, "\26ZM_WEB_H_IMAGE_SCALING\0011\7intege"..., 33) = 33
read(4, "\"\0\0d", 4) = 4
read(4, "\25ZM_WEB_M_REFRESH_MAIN\003300\7integ"..., 34) = 34
read(4, "\"\0\0e", 4) = 4
read(4, "\26ZM_WEB_M_REFRESH_CYCLE\00220\7integ"..., 34) = 34
read(4, "\"\0\0f", 4) = 4
read(4, "\26ZM_WEB_M_REFRESH_IMAGE\00210\7integ"..., 34) = 34
read(4, "\"\0\0g", 4) = 4
read(4, "\27ZM_WEB_M_REFRESH_STATUS\0015\7integ"..., 34) = 34
read(4, "#\0\0h", 4) = 4
read(4, "\27ZM_WEB_M_REFRESH_EVENTS\00260\7inte"..., 35) = 35
read(4, "%\0\0i", 4) = 4
read(4, "\26ZM_WEB_M_VIDEO_BITRATE\00575000\7in"..., 37) = 37
read(4, "!\0\0j", 4) = 4
read(4, "\25ZM_WEB_M_VIDEO_MAXFPS\00210\7intege"..., 33) = 33
read(4, "!\0\0k", 4) = 4
read(4, "\26ZM_WEB_M_IMAGE_SCALING\0014\7intege"..., 33) = 33
read(4, "\"\0\0l", 4) = 4
read(4, "\25ZM_WEB_L_REFRESH_MAIN\003300\7integ"..., 34) = 34
read(4, "\"\0\0m", 4) = 4
read(4, "\26ZM_WEB_L_REFRESH_CYCLE\00230\7integ"..., 34) = 34
read(4, "\"\0\0n", 4) = 4
read(4, "\26ZM_WEB_L_REFRESH_IMAGE\00215\7integ"..., 34) = 34
read(4, "#\0\0o", 4) = 4
read(4, "\27ZM_WEB_L_REFRESH_STATUS\00210\7inte"..., 35) = 35
read(4, "$\0\0p", 4) = 4
read(4, "\27ZM_WEB_L_REFRESH_EVENTS\003180\7int"..., 36) = 36
read(4, "%\0\0q", 4) = 4
read(4, "\26ZM_WEB_L_VIDEO_BITRATE\00525000\7in"..., 37) = 37
read(4, " \0\0r", 4) = 4
read(4, "\25ZM_WEB_L_VIDEO_MAXFPS\0015\7integer", 32) = 32
read(4, "!\0\0s", 4) = 4
read(4, "\26ZM_WEB_L_IMAGE_SCALING\0014\7intege"..., 33) = 33
read(4, "\"\0\0t", 4) = 4
read(4, "\25ZM_WEB_P_REFRESH_MAIN\003300\7integ"..., 34) = 34
read(4, "\"\0\0u", 4) = 4
read(4, "\26ZM_WEB_P_REFRESH_IMAGE\00230\7integ"..., 34) = 34
read(4, "\"\0\0v", 4) = 4
read(4, "\23ZM_DYN_LAST_VERSION\0061.19.0\6stri"..., 34) = 34
read(4, "\"\0\0w", 4) = 4
read(4, "\23ZM_DYN_CURR_VERSION\0061.19.0\6stri"..., 34) = 34
read(4, "%\0\0x", 4) = 4
read(4, "\21ZM_DYN_LAST_CHECK\n1079675990\7in"..., 37) = 37
read(4, "\35\0\0y", 4) = 4
read(4, "\24ZM_DYN_NEXT_REMINDER\0\6string", 29) = 29
read(4, "\1\0\0z", 4) = 4
brk(0) = 0xcab1000
brk(0xcab2000) = 0xcab2000
brk(0) = 0xcab2000
brk(0xcab3000) = 0xcab3000
brk(0) = 0xcab3000
brk(0xcab4000) = 0xcab4000
brk(0) = 0xcab4000
brk(0xcab5000) = 0xcab5000
brk(0) = 0xcab5000
brk(0xcab6000) = 0xcab6000
mmap2(NULL, 233472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4026b000
mmap2(NULL, 233472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x402a4000
brk(0) = 0xcab6000
brk(0xcab7000) = 0xcab7000
gettimeofday({1079685873, 263155}, NULL) = 0
getpid() = 4316
open("/etc/resolv.conf", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=109, ...}) = 0
read(5, "domain voicefx.com\nsearch voicef"..., 4096) = 109
close(5) = 0
socket(PF_UNIX, SOCK_STREAM, 0) = 5
connect(5, {sa_family=AF_UNIX, path="/var/run/.nscd_socket"}, 110) = 0
writev(5, [{"\2\0\0\0\4\0\0\0\24\0\0\0", 12}, {"netcam1.voicefx.com\0", 20}], 2) = 32
read(5, "p&\23B\1\0\0\0\24\0\0\0\0\0\0\0\2\0\0\0\4\0\0\0\1\0\0\0"..., 32) = 32
readv(5, [{"netcam1.voicefx.com\0", 20}, {"", 0}, {"\n\n\n\334", 4}], 3) = 24
read(5, NULL, 0) = 0
close(5) = 0
mmap2(NULL, 233472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x402dd000
shmget(2053971969, 11520248, IPC_CREAT|0x1c0|0600) = 32768
shmat(32768, 0, 0) = 0x40316000
time(NULL) = 1079685873
write(4, "\24\1\0\0\3select Id,Name,Type+0,Units"..., 280) = 280
read(4, "\26", 1) = 1
read(4, "\23\0\0\2", 4) = 4
read(4, "\5Zones\2Id\3\n\0\0\1\3\3\'B\0", 19) = 19
brk(0) = 0xcab7000
brk(0xcab9000) = 0xcab9000
read(4, "\25\0\0\3", 4) = 4
read(4, "\5Zones\4Name\3\377\0\0\1\374\3\21\0\0", 21) = 21
read(4, "\22\0\0\4", 4) = 4
read(4, "\0\6Type+0\3\27\0\0\1\5\3\1\0\37", 18) = 18
read(4, "\5Zones\5Units\3\7\0\0\1\376\3\1\1\0", 22) = 22
read(4, "\24\0\0\6", 4) = 4
read(4, "\5Zones\3LoX\3\5\0\0\1\2\3!\0\0", 20) = 20
read(4, "\24\0\0\7", 4) = 4
read(4, "\5Zones\3LoY\3\5\0\0\1\2\3!\0\0", 20) = 20
read(4, "\24\0\0\10", 4) = 4
read(4, "\5Zones\3HiX\3\5\0\0\1\2\3!\0\0", 20) = 20
read(4, "\24\0\0\t", 4) = 4
read(4, "\5Zones\3HiY\3\5\0\0\1\2\3!\0\0", 20) = 20
read(4, "\31\0\0\n", 4) = 4
read(4, "\5Zones\10AlarmRGB\3\n\0\0\1\3\3 \0\0", 25) = 25
read(4, "\31\0\0\v", 4) = 4
read(4, "\0\rCheckMethod+0\3\27\0\0\1\5\3\1\0\37", 25) = 25
read(4, "\"\0\0\f", 4) = 4
read(4, "\5Zones\21MinPixelThreshold\3\5\0\0\1\2\3 "..., 34) = 34
read(4, "\"\0\0\r", 4) = 4
read(4, "\5Zones\21MaxPixelThreshold\3\5\0\0\1\2\3 "..., 34) = 34
read(4, "\37\0\0\16", 4) = 4
read(4, "\5Zones\16MinAlarmPixels\3\n\0\0\1\3\3 \0\0", 31) = 31
read(4, "\37\0\0\17", 4) = 4
read(4, "\5Zones\16MaxAlarmPixels\3\n\0\0\1\3\3 \0\0", 31) = 31
read(4, "\30\0\0\20", 4) = 4
read(4, "\5Zones\7FilterX\3\3\0\0\1\1\3 \0\0", 24) = 24
read(4, "\30\0\0\21", 4) = 4
read(4, "\5Zones\7FilterY\3\3\0\0\1\1\3 \0\0", 24) = 24
read(4, " \0\0\22", 4) = 4
read(4, "\5Zones\17MinFilterPixels\3\n\0\0\1\3\3 \0\0", 32) = 32
read(4, " \0\0\23", 4) = 4
read(4, "\5Zones\17MaxFilterPixels\3\n\0\0\1\3\3 \0\0", 32) = 32
read(4, "\36\0\0\24", 4) = 4
read(4, "\5Zones\rMinBlobPixels\3\5\0\0\1\2\3 \0\0", 30) = 30
read(4, "\36\0\0\25", 4) = 4
read(4, "\5Zones\rMaxBlobPixels\3\5\0\0\1\2\3 \0\0", 30) = 30
read(4, "\31\0\0\26", 4) = 4
read(4, "\5Zones\10MinBlobs\3\5\0\0\1\2\3 \0\0", 25) = 25
read(4, "\31\0\0\27", 4) = 4
read(4, "\5Zones\10MaxBlobs\3\5\0\0\1\2\3 \0\0", 25) = 25
read(4, "\1\0\0\30", 4) = 4
brk(0) = 0xcab9000
brk(0xcabb000) = 0xcabb000
read(4, "B\0\0\31", 4) = 4
read(4, "\0011\3All\0011\7Percent\0010\0010\003100\003100\01016"..., 66) = 66
brk(0) = 0xcabb000
brk(0xcabd000) = 0xcabd000
read(4, "\1\0\0\32", 4) = 4
gettimeofday({1079685873, 301411}, {300, 0}) = 0
getpid() = 4316
rt_sigaction(SIGPIPE, {0x420db0d0, [], SA_RESTORER, 0x420276f8}, {SIG_IGN}, 8) = 0
send(3, "<142>Mar 19 03:44:33 zmc-m1[4316"..., 57, 0) = 57
rt_sigaction(SIGPIPE, {SIG_IGN}, NULL, 8) = 0
rt_sigaction(SIGTERM, {0x804b300, [], SA_RESTORER, 0x420276f8}, {SIG_DFL}, 8) = 0
rt_sigprocmask(SIG_BLOCK, [USR1 USR2], NULL, 8) = 0
gettimeofday({1079685873, 302213}, {300, 0}) = 0
socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 5
connect(5, {sa_family=AF_INET, sin_port=htons(80), sin_addr=inet_addr("10.10.10.220")}, 16) = 0
write(5, "GET /axis-cgi/jpg/image.cgi?reso"..., 126) = 126
select(6, [5], NULL, NULL, {2, 500}) = 1 (in [5], left {0, 940000})
ioctl(5, FIONREAD, [45]) = 0
read(5, "HTTP/1.0 200 OK\r\nContent-Type: i"..., 45) = 45
close(5) = 0
write(2, "Empty input file\n", 17Empty input file
) = 17
exit_group(1) = ?
Thanks alot for any help..
-- Cy
Axis 2100 "Empty input file"
- zoneminder
- Site Admin
- Contact:
Re: Axis 2100 "Empty input file"
This issue has been reported and there is a thread about it <a href="http://www.zoneminder.com/forum_install ... a">here</a>. It is because older Axis cameras do not send a content-length header. I hope to have a fix out for it today but in the meantime check out the other thread.
Cheers,
Phil,
Cheers,
Phil,
Thanks alot for the speedy reply, much appreciated as I can stop banging my head against a brick wall :)
Looking forward to getting to play with ZM
-- Cy
-- Cy
- zoneminder
- Site Admin
- Contact:
Hi again,
I've put a test fix up and detailed it on <a href="http://www.zoneminder.com/forum_install ... e65a">this thread</a>. If you get chance could you try it out and report back on that thread so I have all the responses together.
Cheers,
Phil,
Cheers,
Phil,
