Post Event Image Buffer
dbw
Post by dbw »
hey everyone,
im currently using ZM v1.21.3 on FC3, but im having trouble getting the Post Event Image Buffer to work effectively. From what i understand this is the amount of frames that will be recorded after the motion stops. So as my cam (dlink dcs-900) is running at 15 fps, i set this to 450 which should record an extra 30 seconds of footage? however i am not getting anything more than the few seconds which contained motion.
any help would be appreciated,
jared.
zoneminder
Site Admin
Post by zoneminder »
Have you tried it with a range of smaller values first to check that it is being saved correctly and behaving itself?
Phil
