Problems with Grandtec 16 Port Card
olpau
Post by olpau »
I use Ubuntu 5.10 and a 4 port Grandtec card. The 4 port card works fine. Now I got a 16 port card and this card does not work.
Here is my syslog:
[ 60.753777] bttv: driver version 0.9.15 loaded
[ 60.753784] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 60.755579] bttv: Bt8xx card found (0).
[ 60.755619] bttv0: Bt878 (rev 17) at 0000:00:08.0, irq: 16, latency: 32, mmio : 0xdddfe000
[ 60.755653] bttv0: detected: Grandtec Grand X-Guard [card=103], PCI subsystem ID is 0304:0102
[ 60.755659] bttv0: using: Grand X-Guard / Trust 814PCI [card=103,insmod optio n]
[ 60.755711] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 60.759860] bttv0: using tuner=4
[ 60.759870] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[ 60.817484] bttv0: registered device video0
[ 60.819154] bttv0: registered device vbi0
[ 60.819185] bttv0: PLL: 28636363 => 35468950 .. ok
[ 60.915480] bttv: Bt8xx card found (1).
[ 60.915518] bttv1: Bt878 (rev 17) at 0000:00:09.0, irq: 17, latency: 32, mmio : 0xdddfc000
[ 60.915552] bttv1: subsystem: 8384:8182 (UNKNOWN)
[ 60.915561] bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 60.915615] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 61.045798] bttv1: using tuner=-1
[ 61.045806] bttv1: i2c: checking for MSP34xx @ 0x80... not found
[ 61.047957] bttv1: i2c: checking for TDA9875 @ 0xb0... not found
[ 61.050098] bttv1: i2c: checking for TDA7432 @ 0x8a... not found
[ 61.052244] bttv1: i2c: checking for TDA9887 @ 0x86... not found
[ 61.056137] bttv1: registered device video1
[ 61.057855] bttv1: registered device vbi1
tux
Post by tux »
What dvr is?
I think you need add options for bttv module
olpau
Post by olpau »
Solved: I have to specify the second card as type 103. If I use "modprobe bttv card=103,103" the second card works fine.
zoneminder
Site Admin
Post by zoneminder »
Good. Thanks for the feedback.
Phil
