I'm new to ZoneMinder and installed the actual version for the first time yesterday. Now I have the following problem.
When starting "zmc -d /dev/video0" it crashes. A backtrace with gdb shows the following:
Program received signal SIGSEGV, Segmentation fault.
0x402fd00e in _int_malloc () from /lib/i686/libc.so.6
#0 0x402fd00e in _int_malloc () from /lib/i686/libc.so.6
#1 0x402fc06c in malloc () from /lib/i686/libc.so.6
#2 0x4023369e in operator new(unsigned) () from /usr/lib/libstdc++.so.5
#3 0x402337cd in operator new[](unsigned) () from /usr/lib/libstdc++.so.5
#4 0x0804e0c6 in Polygon (this=0xbffff0e0, p_n_coords=2, p_coords=0xde2d6c8)
at zm_poly.cpp:55
#5 0x08056ffc in Zone::ParsePolygonString(char const*, Polygon&) (
poly_string=0xbffff0e0 "\002", polygon=@0xbffff1d0) at zm_zone.cpp:768
#6 0x08057617 in Zone::Load(Monitor*, Zone**&) (monitor=0xde079f0,
zones=@0xbffff2ac) at zm_zone.cpp:873
#7 0x08062b04 in Monitor::LoadLocalMonitors(char const*, Monitor**&, Monitor::Purpose) (device=0x403b8a74 "Ð5ã\rÐÖâ\r", monitors=@0xbffff338, purpose=CAPTURE)
at zm_monitor.cpp:1253
#8 0x0804bc07 in main (argc=-1073744130, argv=0xbffff574) at zmc.cpp:161
/*if ( !ParsePolygonString( Coords, polygon ) )
continue;
Has anyone an idea how to solve this issue?
Greetings Michael
