Hi, all,
ZoneMinder 1.22 works very well on my FC4, but the cambozola.jar. Any idea?
Where should this error log be?
Regards,
blacksmith
cambozola.jar not work
Cambozola.jar should be installed somewhere in you web root (/var/www/html/zm/cambozola.jar for example). Then in you configuration options under the tools tab you should have ZM_OPT_CAMBOZOLA checked and for ZM_PATH_CAMBOZOLA /zm/cambozola.jar, and also under the video tab ZM_VIDEO_STREAM_METHOD needs to be jpeg for cambozola to be used.
cambozola does not produce an error log and any errors you should see on the browser your calling it with. If it does not load then either you have something configured wrong on the server or the securities are to strict on your browser or your missing a java client.
Regards,
Corey
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
Both should be ok, the first is an absolute path and the last a relative one (from the zm directory). Usually just cambozola.jar is recommended.blacksmith wrote:Befor I feedback a further test report, I found the default value of ZM_PATH_CAMBOZOLA is just cambozola.jar not /zm/cambozola.jar. Which one is correct?
Phil
