ZM 1.22.0 Problems with shared memory. And su.
r0y
Post by r0y »
Hi i've got some problems with 1.22.0 here are the erros:
Feb 7 13:56:47 surveilance zmpkg[21249]: ERR [Unable to find valid 'su' syntax]
And lots of these:
Feb 7 13:58:26 surveilance zmu[21340]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
I've tryed to increase memory now its:
shmall: 154217728
shmmax: 154217728
How much memory do i have to set here and how to fix the invalid syntax?
/Roy
zoneminder
Site Admin
Post by zoneminder »
Can you tell us what distro you are using?
Phil
r0y
Post by r0y »
Sorry, its a fresh gentoo install.
r0y
Post by r0y »
Any one got a ide? I need to get this setup up and running becasue i want to se if those ppl in the appartment downstairs are stealing food from us.. hehe
tech_fixer
Post by tech_fixer »
My best advice: use a more thoroughly tested Linux distribution as your plattform. I'm using Fedora Core 4 and it works wonderfully. Only took me 2 hours to set everything up from scratch.
And with Cordel's RPM, it should be even a quicker install!
Regards,
Jose.
zoneminder
Site Admin
There are plenty of people running ZM on gentoo so I'm a little surprised why you are getting the su error. Can you edit your installed zmpkg.pl and change the value of DBG_LEVEL to 1. Then try and start ZM and post the relevant parts of your zmpkg.log file.
Phil
r0y
Post by r0y »
tech_fixer wrote:My best advice: use a more thoroughly tested Linux distribution as your plattform. I'm using Fedora Core 4 and it works wonderfully. Only took me 2 hours to set everything up from scratch.
Regards,
Jose.
Well i don't like RedHat/Fedora, and found that the only distro i like is gentoo, i did however try the Livecd but i didn't get any picture. And all of my computers witch is runnig linux is running gentoo :)
r0y
Post by r0y »
Ok with debug level 1 here it is:
/var/log/messages
Feb 8 22:48:38 surveilance zmpkg[25194]: INF [Command: start]
Feb 8 22:48:38 surveilance su(pam_unix)[25197]: session opened for user apache by (uid=0)
Feb 8 22:48:38 surveilance su(pam_unix)[25197]: session closed for user apache
Feb 8 22:48:38 surveilance su(pam_unix)[25199]: session opened for user apache by (uid=0)
Feb 8 22:48:38 surveilance su(pam_unix)[25199]: session closed for user apache
Feb 8 22:48:38 surveilance zmpkg[25194]: ERR [Unable to find valid 'su' syntax]
zmpkg.log
02/08/06 22:48:38.813011 zmpkg[25194].INF [Command: start]
02/08/06 22:48:38.828974 zmpkg[25194].DBG [Testing valid shell syntax]
02/08/06 22:48:38.829740 zmpkg[25194].DBG [Testing 'su apache -c 'true'']
02/08/06 22:48:38.944176 zmpkg[25194].DBG [Test failed, '']
02/08/06 22:48:38.944717 zmpkg[25194].DBG [Testing 'su apache --shell=/bin/sh --command='true'']
02/08/06 22:48:38.970428 zmpkg[25194].DBG [Test failed, '']
02/08/06 22:48:38.970922 zmpkg[25194].ERR [Unable to find valid 'su' syntax]
zoneminder
Site Admin
r0y wrote:su apache -c 'true'
Can you try those two commands interactively and post what you get.
Phil
r0y
Post by r0y »
I tihnk i know whats wrong
su apache --shell=/bin/sh --command='true'' <- one too many of '
Here is goes:
surveilance zoneminder # su apache -c 'true'
surveilance zoneminder # su apache --shell=/bin/sh --command='true''
zoneminder
Site Admin
I think that was just me making a cut'n'paste typo. Actually what we need to know is whwther the command succeeded, so try this
su apache -c 'true'
echo $?
echo $?
Phil
lazyleopard
Post by lazyleopard »
The apache user may need a shell defined? The default Gentoo install sets apache's shell to /bin/false.
Rick Hewett
zoneminder
Site Admin
Yes, I think I'll change this for 1.22.1 to fork and exec instead.
Phil
r0y
Post by r0y »
Thats nice, but any workarounds now? Cause i really need this up and running :)
lazyleopard
Try using vipw to edit /etc/passwd, changing
apache:x:81:81:apache:/www:/bin/false
to
apache:x:81:81:apache:/www:/bin/bash
Rick Hewett
