change in brightness
gungner
Post by gungner »
Two of my four cameras are getting darker and darker during the day and then they get back to normal brightness when it gets dark outsude. Before the update to 1.22 it was only one camera and I thought it was a problem with the camera, but now when I get it on two cameras I wonder.
For a sample please have a look at http://www.tabykyrkby.net/files/Event-49-r1-s1.mpg
Anything to tweek on zma?
cheers, tord[/url]
mlrtime3
Post by mlrtime3 »
Mine doesn't get that dark but I have basically the same problem. The brightness seems to change randomly during the day and it causes the alert to trigger.
I don't know if this is an issue with the camera because I've never seen it with the analog out but I'm not sure.
zoneminder
Site Admin
Post by zoneminder »
I'm sorry I don't have the link but someone posted a brightness control script (try the User Contribs forum) which was for a different purpose but which might help.
Phil
jameswilson
Post by jameswilson »
usually this indicates a problem with the lens or ei circiut on the camera. To confirm run an internal camera through zm or a normal video source such as tv to test
James Wilson
gungner
Script
Post by gungner »
Thanks for the information. I found the script at :
http://www.zoneminder.com/forums/viewto ... brightness
and will give it a try. Thanks
cheers,[/url]
