zmc seg faults
jordg
zmc seg faults
Post by jordg »
Viewing the webcam on zoneminder gives a blank page. In the debug it says:
02/13/06 20:44:44.039709 zmdc[7560].INF [Starting pending process, zmc -d /dev/video0]
02/13/06 20:44:44.041541 zmdc[7614].INF ['zmc -d /dev/video0' started at 06/02/13 20:44:44]
02/13/06 20:44:44.049573 zmdc[7560].INF ['zmc -d /dev/video0' starting at 06/02/13 20:44:44, pid = 7614]
02/13/06 20:44:44.709233 zmdc[7560].INF ['zmc -d /dev/video0' died, signal 10]
If I run it from the command line "zmc -d /dev/video0" it segfaults.
I can run the webcam through xawtv OK.
Help please
cordel
Post by cordel »
Is there any relivant info in your messages or zmpkg.log?
What returns when you run dmesg |grep bttv ?
Also it might be helpfull to know what distro uname -a
Regards,
Corey
jordg
Post by jordg »
dmesg |grep bttv
bttv: driver version 0.9.15 loaded
bttv: using 4 buffers with 2080k (520 pages) each for capture
Custom kernel on Debian Sarge
uname -a
Linux ob1 2.6.12athlon #1 Sat Aug 6 09:18:10 EST 2005 i686 GNU/Linux
==> /tmp/zmdc.log <==
02/13/06 21:57:15.953057 zmdc[8742].INF [Server starting at 06/02/13 21:57:15]
==> /tmp/zmpkg.log <==
02/13/06 21:57:15.446431 zmpkg[8730].INF [Command: start]
02/13/06 21:57:15.447491 zmpkg[8730].DBG [Testing valid shell syntax]
02/13/06 21:57:15.447803 zmpkg[8730].DBG [Running as 'www-data', su commands not needed]
02/13/06 21:57:15.447889 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl check]
02/13/06 21:57:15.695368 zmpkg[8730].DBG [Output: stopped]
02/13/06 21:57:15.695581 zmpkg[8730].DBG [Removing shared memory]
02/13/06 21:57:15.695682 zmpkg[8730].DBG [Checking for shared memory with 'ipcs -m | grep '^0x7a6d20'']
02/13/06 21:57:15.706137 zmpkg[8730].DBG [Command: /usr/local/bin/zmfix]
02/13/06 21:57:15.737415 zmpkg[8730].DBG [Output: ]
02/13/06 21:57:15.737663 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl startup]
02/13/06 21:57:19.219171 zmdc[8765].INF ['zmc -d /dev/video0' started at 06/02/13 21:57:19]
02/13/06 21:57:19.227895 zmdc[8742].INF ['zmc -d /dev/video0' starting at 06/02/13 21:57:19, pid = 8765]
02/13/06 21:57:18.978166 zmpkg[8730].DBG [Output: Starting server]
02/13/06 21:57:18.979505 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl start zmc -d /dev/video0]
02/13/06 21:57:19.536592 zmdc[8769].INF ['zmfilter.pl' started at 06/02/13 21:57:19]
02/13/06 21:57:19.554489 zmdc[8742].INF ['zmfilter.pl' starting at 06/02/13 21:57:19, pid = 8769]
==> /tmp/zmfilter.log <==
02/13/06 21:57:20.075739 zmfilter[8769].INF [Scanning for events]
02/13/06 21:57:19.280188 zmpkg[8730].DBG [Output: 'zmc -d /dev/video0' started at 06/02/13 21:57:19
02/13/06 21:57:19.280727 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl start zmfilter.pl]
02/13/06 21:57:20.085421 zmpkg[8730].DBG [Output: 'zmfilter.pl' started at 06/02/13 21:57:19
02/13/06 21:57:20.085734 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl start zmaudit.pl -c]
==> /tmp/zmaudit.log <==
02/13/06 21:57:20.578303 zmaudit[8774].DBG [Found database monitor '1']
02/13/06 21:57:20.579317 zmaudit[8774].DBG [Got 0 events]
02/13/06 21:57:20.580169 zmaudit[8774].DBG [Found database monitor '2']
02/13/06 21:57:20.580704 zmaudit[8774].DBG [Got 0 events]
02/13/06 21:57:20.581184 zmaudit[8774].DBG [Found filesystem monitor '1']
02/13/06 21:57:20.581365 zmaudit[8774].DBG [Got 0 events]
02/13/06 21:57:20.581413 zmaudit[8774].DBG [Found filesystem monitor '2']
02/13/06 21:57:20.581508 zmaudit[8774].DBG [Got 0 events]
02/13/06 21:57:20.352305 zmdc[8774].INF ['zmaudit.pl -c' started at 06/02/13 21:57:20]
02/13/06 21:57:20.360203 zmdc[8742].INF ['zmaudit.pl -c' starting at 06/02/13 21:57:20, pid = 8774]
02/13/06 21:57:20.803084 zmdc[8779].INF ['zmwatch.pl' started at 06/02/13 21:57:20]
02/13/06 21:57:20.806055 zmdc[8742].INF ['zmwatch.pl' starting at 06/02/13 21:57:20, pid = 8779]
02/13/06 21:57:20.592389 zmpkg[8730].DBG [Output: 'zmaudit.pl -c' started at 06/02/13 21:57:20
02/13/06 21:57:20.592635 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl start zmwatch.pl]
02/13/06 21:57:21.024509 zmpkg[8730].DBG [Output: 'zmwatch.pl' started at 06/02/13 21:57:20
02/13/06 21:57:21.024781 zmpkg[8730].DBG [Command: /usr/local/bin/zmdc.pl start zmupdate.pl -c]
==> /tmp/zmwatch.log <==
02/13/06 21:57:21.013652 zmwatch[8779].INF [Watchdog starting]
02/13/06 21:57:21.014692 zmwatch[8779].INF [Watchdog pausing for 30 seconds]
02/13/06 21:57:21.276449 zmdc[8742].INF ['zmc -d /dev/video0' died, signal 10]
02/13/06 21:57:21.277060 zmdc[8742].INF [Starting pending process, zmc -d /dev/video0]
02/13/06 21:57:21.278987 zmdc[8742].INF ['zmc -d /dev/video0' starting at 06/02/13 21:57:21, pid = 8783]
02/13/06 21:57:21.282826 zmdc[8783].INF ['zmc -d /dev/video0' started at 06/02/13 21:57:21]
02/13/06 21:57:21.396004 zmdc[8785].INF ['zmupdate.pl -c' started at 06/02/13 21:57:21]
02/13/06 21:57:21.400025 zmdc[8742].INF ['zmupdate.pl -c' starting at 06/02/13 21:57:21, pid = 8785]
02/13/06 21:57:21.410843 zmpkg[8730].DBG [Output: 'zmupdate.pl -c' started at 06/02/13 21:57:21
02/13/06 21:57:23.922666 zmdc[8742].INF ['zmc -d /dev/video0' died, signal 10]
02/13/06 21:57:28.035080 zmdc[8742].INF [Starting pending process, zmc -d /dev/video0]
02/13/06 21:57:28.037011 zmdc[8796].INF ['zmc -d /dev/video0' started at 06/02/13 21:57:28]
02/13/06 21:57:28.039235 zmdc[8742].INF ['zmc -d /dev/video0' starting at 06/02/13 21:57:28, pid = 8796]
02/13/06 21:57:28.771008 zmdc[8742].INF ['zmc -d /dev/video0' died, signal 10]
Cheers
Grahame
cordel
Post by cordel »
Thanks for sorting out the logs but you really don't need to.
Whats in you messages or syslog?
what returns with:
zmu -d /dev/video0 -q -v
Corey
jordg
Post by jordg »
That was a tail -f /tmp/z*log
/var/log/messages stuff
Feb 13 22:07:59 ob1 zmdc[8742]: INF [Starting pending process, zmc -d /dev/video0]
Feb 13 22:07:59 ob1 zmdc[8975]: INF ['zmc -d /dev/video0' started at 06/02/13 22:07:59]
Feb 13 22:07:59 ob1 zmdc[8742]: INF ['zmc -d /dev/video0' starting at 06/02/13 22:07:59, pid = 8975]
Feb 13 22:07:59 ob1 zmc_dvideo0[8975]: INF [Debug Level = 0, Debug Log = <none>]
Feb 13 22:08:00 ob1 zmc_dvideo0[8975]: ERR [Failed to set picture attributes: Invalid argument]
Feb 13 22:08:00 ob1 zmdc[8742]: INF ['zmc -d /dev/video0' died, signal 10]
root@ob1:~# zmu -d /dev/video0 -q -v
Video Capabilities
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 352
Maximum Height: 288
Minimum Width: 176
Minimum Height: 144
Window Attributes
X Offset: 0
Y Offset: 0
Width: 176
Height: 144
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
cordel
Post by cordel »
jordg wrote: Feb 13 22:08:00 ob1 zmc_dvideo0[8975]: ERR [Failed to set picture attributes: Invalid argument]
Bingo, If you can get a jpeg snapshot from the web cam, check the attributes and set zm to match. It's cranky about the image attributes you have defined for the monitor.
Cheers,
Corey
jordg
Post by jordg »
Mmmm? On xawtv I get a "Grabbing failed" message
Grahame
cordel
Post by cordel »
:? Thats not good. You might want to search on the forum or google for info on your cam. If xawtv can't get a snapshot then zm will not be able to either. You could see if this turns up anything:
xawtv -hwscan
I haven't used a web cam so I'm not to privy on what it might take to get it going.
jordg
Post by jordg »
I will look on google and try again :)
gbj@ob1:~$ xawtv -hwscan
This is xawtv-3.94, running on Linux/i686 (2.6.12athlon)
looking for available devices
port 61-61
type : Xvideo, image scaler
name : 3dfx Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : v4l
flags: capture
Thanks so far for your help
cordel
Post by cordel »
Here is something you might wish to look into:
http://www.zoneminder.com/forums/viewto ... ht=express
Corey
