Hi!
I have installed Zm 1.22.0 in my Slackware 10.2. I have also a Grandtec PCI Card 4 port.
My installation go away without particular problem with tutorial published by this site for Slackware user, but when I connect my VideoCamera to card I don't see anything. In montage I see 3/4 fps capturing frame by my card...so my card seems to work correctly, but in place of image I see Icons that application shows when thereisn't plugin for the type of file. Do you understand me?
Sorry for my BAD BAD BAD English...
Where is my error? What I forgot?
Thanks for your help!
Alessandro
Problem to view Image in Monitor
There are a couple places to look. By default ZM puts its logs in /tmp and most errors are in either zmdc or zmpkg.log or in your /var/log/messages ( or /var/log/syslog depending on what slack uses).
The other place to look and in your case I think you might be able to find the problem in the apache error_log.
Regards,
Corey
Regards,
Corey
