Internet Explorer can't login ?
wimg
Post by wimg »
Does anyone know why I can't login to ZoneMinder with Internet Explorer ? I tried on several systems, but I just get the login screen again. Netscape 7.x is no problem, but IE doens't work.
zoneminder
Site Admin
Re: Internet Explorer can't login ?
Post by zoneminder »
Hi Wim,
Do you have cookies enabled? That is the only thing you really need to authentication to work. Alternatively you can run in non-authenticated mode.
Phil,
wimg
Post by wimg »
That problem seems to be solved now... I reinstalled completely and it works.
However, now I have this problem :
- If I enable mpeg-generation for live stream, my Netscape asks for an external application.
- Internet Explorer still won't display a live stream, it will only show 1 image.
zoneminder
Site Admin
IE won't play a motion jpeg stream, but it should be able to manage an 'asf' video stream, if you have the Windows Media Player plugin. Is that what you mean?
Phil,
wimg
Post by wimg »
Yes that's what I mean. It won't start the asf video stream. It just displays me 1 picture, that's it.
