No image
jameswilson
Post by jameswilson »
id jump straight to 5 mate if its in the pipeline as fc3 is still doing a grand job
James Wilson
cordel
Post by cordel »
It depends on the chip set that you have on your card.
If it is a Conexant 878, it should be auto detected by the 2.6 series kernel.
If it is a Philips chip, then you have to go with a 2.6.15 kernel and cross your fingers kinda thing (I haven't yet had the chance to test the newer kworld cards with the Phillips chips).
AusIV
Post by AusIV »
The card seems to be recognized, but as I've said, the problem is that I'm not seeing anything. Would that have anything to do with the detection?
-Edit-
I took out my graphics card and confirmed that it has a connexant chip.
cordel
Post by cordel »
AusIV wrote: Also, here is dmesg | grep bttv
[4294715.159000] bttv: driver version 0.9.15 loaded
[4294715.159000] bttv: using 8 buffers with 2080k (520 pages) each for capture
[4294715.172000] bttv: Bt8xx card found (0).
[4294715.172000] bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 5, latency: 32, mmio: 0xd6000000
[4294715.172000] bttv0: using: Jetway TV/Capture JW-TV878-FBK, Kworld KW-TV878RF [card=78,insmod option]
[4294715.172000] bttv0: gpio: en=00000000, out=00000000 in=00ffea01 [init]
[4294715.201000] bttv0: using tuner=5
[4294715.201000] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[4294715.203000] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[4294715.205000] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[4294715.309000] bttv0: registered device video0
[4294715.325000] bttv0: registered device vbi0
[4294715.369000] bttv0: registered device radio0
[4294715.369000] bttv0: PLL: 28636363 => 35468950 .. ok
That shows that you set the value your self and it is not going to use any autodetection as you are forcing the settings. So unless this has changed...
I'm not sure what card type you should be using though. The one you selected might be correct. Does this board have a tuner on it? This driver sure thinks it does.
AusIV
Post by AusIV »
Ok, I the dmesg I showed before was after changing my modprobe.conf as suggested by jameswilson. After removing that, I get the following dmesg:
[4294715.902000] bttv: driver version 0.9.15 loaded
[4294715.902000] bttv: using 8 buffers with 2080k (520 pages) each for capture
[4294715.914000] bttv: Bt8xx card found (0).
[4294715.915000] bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 5, latency: 32, mmio: 0xd6000000
[4294715.915000] bttv0: using:  *** UNKNOWN/GENERIC ***  [card=0,autodetected]
[4294715.915000] bttv0: gpio: en=00000000, out=00000000 in=00ffea01 [init]
[4294715.955000] tveeprom(bttv internal): Huh, no eeprom present (err=-121)?
[4294715.955000] bttv0: using tuner=-1
[4294715.955000] bttv0: i2c: checking for MSP34xx @ 0x80... not found
[4294715.957000] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[4294715.959000] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[4294715.962000] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[4294715.991000] bttv0: registered device video0
[4294716.011000] bttv0: registered device vbi0
With these settings, zoneminder is completely unresponsive to whether or not there is a video signal, and shows a red screen regardless of whether or not there is a signal.
Also, thanks for all the help. The response time here is amazing.
cordel
Post by cordel »
Okay, I think we need to back up a bit.
First what linix flavor are you using?
Kernel version?
Is there any chance you could post a picture of the card?
Regards,
Corey
AusIV
Post by AusIV »
I'm using Ubuntu, Breezey Badger. The kernel version is 2.6.12-10-386.
I don't reall have the resources to take a picture of the card myself, but this picture is the generic picture that resellers put with the card:
AusIV
-Update-
Post by AusIV »
Ok, I finally got to try the video card in a system with more resources. I used the Live CD because I'm not allowed to install an operating system on this machine, and it's normally windows. I used Xawtv to look at the video card, and saw nothing but black images.
The thing that confused me, was that the signals were labeled things like "television" and "composite 1". Are these arbitrary names, or is it expecting a kind of signal it's not receiving?
zoneminder
Site Admin
Post by zoneminder »
They are labels that usually correspond to the inputs that your card would expect but other than that are not usually significant.
Phil
coolcheeze
Post by coolcheeze »
i had the same issue with a similar card with debian... I was running an older 2.6 series kernel and then updated to the 2.6.15 kernel and it solved my 'black screen' issues in fact my dmesg output was almost identical to yours.
