ok here it is,
Suse 10 x86_64
webcam logitech quickcam communicate STX with spca5xx
apache 2.0.54
Mysql 4.1.13
all requirements ok
configured properly...
streaming works with , xawtv ,gqcam and other applications
Symptom : no streaming at all (monitor, etc), Zone produces the image just fine , Record produces events but browser(s) show nothing out of the : http://localhost/cgi-bin/nph-zms?mode=j ... 1140603604 OR plain zms
Checked all zm logs and apache2 messages and can't find anything interesting other than below :
warn.log : Feb 22 11:14:40 localhost zmc_dvideo0[6368]: ERR [Failed to set picture attributes: Invalid argument]
zmu -q -d/dev/video0 -v
Video Capabilities
Name: Logitech QuickCam Communicate STX
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 176
Minimum Height: 144
Window Attributes
X Offset: 0
Y Offset: 0
Width: 384
Height: 288
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Apologize in advance if this is a v4l or camera/driver problem or just ME but after a thorough search i found others with exact same probs and tried all proposed remedies without success
No image?? no clue
It must be something with zms, nph-zms. You can try to get images directly from url:
http://localhost/cgi-bin/nph-zms?mode=j ... &scale=100
and
http://localhost/cgi-bin/zms?mode=jpeg& ... &scale=100
check your error.log and access.log of apache - /var/log/apache/ - that's the path in my debian, should be almost the same in your distro.
Please post your a part of log when you open monitor in browser.
and
I don't get anything directly other than the binary (save as) or the execution on konqueror for examplemaciekc wrote:It must be something with zms, nph-zms. You can try to get images directly from url:
and
That's is the thing, i just get only this from access.log and nothing from error :maciekc wrote:check your error.log and access.log of apache - /var/log/apache/ - that's the path in my debian, should be almost the same in your distro.
10.0.0.1 - - [24/Feb/2006:08:29:18 +0200] "GET /zm/zm.php?view=watchevents&max_events=10&mid=1 HTTP/1.1" 200 3643 "http://localhost/zm/zm.php?view=watch&m ... &scale=100" "Mozilla/5.0 (X11; U; Linux i686 (x86_64); en-US; rv:1. Gecko/20051111 Firefox/1.5"
- zoneminder
- Site Admin
- Contact:
