I believe I've installed everything correctly. But the databsae is not populated with any data. When I try to start zm (from the scripts directory "./zm start") I get:
Output of ./zm start
I gather that this is because there is no data in the database.Starting ZoneMinder: DBD::mysql::st execute failed: Table 'mscam.Config' doesn't exist at /usr/lib/perl5/site_perl/5.8.6/ZoneMinder/Config.pm line 91.
Can't execute: Table 'mscam.Config' doesn't exist at /usr/lib/perl5/site_perl/5.8.6/ZoneMinder/Config.pm line 99
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.6/ZoneMinder/Config.pm line 99.
Compilation failed in require at /usr/lib/perl5/site_perl/5.8.6/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.6/ZoneMinder.pm line 33.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 45.
zm.conf:
How do I go about populating the database? Isn't this done automatically during one of the scripts? zmupdate.pl gives me the same error as above. I read somewhere about an zminit, but I cant find that, I assume it's from an older version.# Current version of ZoneMinder
ZM_VERSION=1.22.0
# Path to build directory, used mostly for finding DB upgrade scripts
ZM_PATH_BUILD=/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0
# Build time, used to record when to trigger various checks
ZM_TIME_BUILD=1140800784
# Path to ZoneMinder binaries
ZM_PATH_BIN=/usr/local/bin
# Path to ZoneMinder libraries (none at present, for future use)
ZM_PATH_LIB=/usr/local/lib
# Path to ZoneMinder configuration (this file only at present)
ZM_PATH_CONF=/usr/local/etc
# Path to ZoneMinder web files
ZM_PATH_WEB=/srv/www/htdocs/ms
# Path to ZoneMinder cgi files
ZM_PATH_CGI=/srv/www/cgi-bin
# Username and group that web daemon (httpd/apache) runs as
ZM_WEB_USER=wwwrun
ZM_WEB_GROUP=www
# ZoneMinder database hostname or ip address
ZM_DB_HOST=localhost
# ZoneMinder database name
ZM_DB_NAME=mscam
# ZoneMinder database user
ZM_DB_USER=root
# ZoneMinder database password
ZM_DB_PASS=hidden
Also I'm a bit confused as to whether my installation finished correctly. The last few lines of the 'make install' are:
It just seems to all end ever so abruptly. (I'm a newbie to Linux if you haven't guessed already).Making install in db
make[1]: Entering directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0/db'
make[2]: Entering directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0/db'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0/db'
make[1]: Leaving directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0/db'
make[1]: Entering directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
make[2]: Entering directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
test -z "/usr/local/etc" || mkdir -p -- "/usr/local/etc"
/usr/bin/install -c -m 644 'zm.conf' '/usr/local/etc/zm.conf'
make install-data-hook
make[3]: Entering directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
( cd /usr/local/etc; chown wwwrun:www zm.conf; chmod 600 zm.conf )
( if ! test -e /var/run; then mkdir /var/run; fi )
( if ! test -e /var/run/zm; then mkdir /var/run/zm; fi; chown wwwrun:www /var/run/zm; chmod u+w /var/run/zm )
make[3]: Leaving directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
make[2]: Leaving directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
make[1]: Leaving directory `/srv/files/temp/ZoneMinder-1.22.0/ZoneMinder-1.22.0'
My system is:
SuSE Linux 9.3 Professional
Tab Window Manager
VIA C3 800MHz, 256Mb RAM
zoneminder-1.22.0
mysql-4.1.10a
perl-5.8.6
kernel-2.6.11.4-20a-default
If you need any more information just say. Any help would be greatly appreciated.
Thanks,
Mik.
