Am running zm 1.21.4 and have the track motion set up. Originally i had this set to return the camera to the home position after 60 seconds, this worked fine. I now need it to return to preset1.
If i click preset1 on the zm's camera control page it goes to the correct postion so ZM must be able to tell the camera to go to a preset.
I looked in the zmtrack.log and shows "Returning to location 1" but the camera doesn't move. It does still track motion correctly though.
In the zmtrack pl file this seems to be the problem line
--command=".($monitor->{ReturnLocation}?"preset1":"preset_home");
now in other parts of ZM preset1 is called preset_1 or preset 1 or preset_goto_1 i've tried all of them and none seem to work.
Anyone got any ideas or is anyone else using preset1 sucessfully?
(Camera is a BL-C10 and is running on centos 4.2)
thanks
James
Track Motion and Preset 1
i have 'played' with a c10 and tracking but gave up, i cant help with your preset 1 thing but you could use (i did) the panasonic ui to change the home position to match preset 1
James Wilson
- zoneminder
- Site Admin
- Contact:
