I am a total green horn to linux but managed to get ZoneMinder FC3 CTU Distro v1.21.3 up and running OK.
However the problem I have is that any monitor on any port of the installed Conexant 878A four input card produces a badly overscaned non synching monitor window.
I have tried numerous resolution settings but none have produce a synced signal. I am useing comon 400line PAL cameras.
The same machine ( and card ) performs OK under WIN32 apps (but does not have the features that ZM will provide I hope).
I have read a thread called "CTU video Question" and suspect this could be the problem. What should be in the modprode.conf for my 878A card??
Or what other problems should I look for.?
Ta Rock
Overscan, sync PAL camera problem
It works now.
Added "options bttv card=77" to /etc/modprobe.conf
NB card is same as in topic "generic 4 port bt878 based card"
http://www.zoneminder.com/forums/viewtopic.php?t=4280
Ta Rock
Ta Rock
