which uses less bandwidth: mpeg or jpeg?
semotta
Post by semotta »
I was wondering, which is better in terms of bandwidth use: to send video stream using mpeg or continuous jpeg images? Does it make any difference?
Thanks,
Sergio.
Flash_
Post by Flash_ »
Never done a like-for-like comparison, but you can screw down mjpeg to really very little by limiting the size, colour and fps at the camera end. I have 7 640x480 b&w streams camera-limited to 5fps running through a normal 100mbit lan with no signs of choking. ZM chugged quite a bit with them until I upped the hardware to cope.
You can also adjust the compression on mjpeg, but I understand it's a tradeoff between bandwidth and increased CPU utilisation.
zoneminder
Site Admin
Post by zoneminder »
I think technically mpeg uses less bandwidth as it just sends the differences between frames each time, plus other optimisations. However mpeg streams often seem to suffer from lag problems so I prefer the immediacyand simplicity of mpjpeg streams.
Phil
