Rescalling is also needed in other modes so it's good idea when you have diffrent sizes as you said. I agree.Im not sure i agree. I see what your saying that you always use a particular size but i for one dont. I aslo aim to get this to the tv out of the gfx card ultimatly. I think once we move to raw images the rescaling will not be an issue. I am not convinced on thios one,
But should be also option manual when you can set x,y and scale for every camera you specify. This way we should be able to make very cool view.
But the text with camera name/date/time is always bad quality after rescalling. The best way to fix the text would be to make this text by zm4linux not by zms.
We can also write a simple script for running that will change config files. That wouldn't be problem for me to write this in bash. Simple and functional:) But command line switches would we much easier.True i like your thinking here. I will see if i can impliment command line switches
I know that zm is Phil's work. I just wanted to tell you to upgrade fast to see his great job:)I personally need raw support on the windows viewer so i will definetly be implimenting this lol. btw zm 1.22 is nothing to do with me, the god that is Phil is the one responsible
Ok I'll try:)Do as you are ideas, bug finding etc all needed as i dont have time to write these things and fully test them in the little spare time i actually have! lol
The one annoying me in Windows Viever is that it doesn't have constant width to height. I'll explain it because I can't find a word for that:)
So we have image size 400x300.
You can make from it 500x200. This shouldn't be possible.
You should make it that 400*k=300*k so the image is always good looking. I hope you understand:)
