logging in
cyclemart
logging in
Post by cyclemart »
If this has been covered before, please excuse this post.
I have recently decided to try and use Ubuntu and ZoneMinder to get 4 CCTV cameras running at a business I own.
After following the Ubuntu install document, things seem to be running, but I cannot login via the web page. I enter admin admin, and it says logging in, then returns to the sign on page.
ZoneMinder was installed using apt-get install zm, and I did install all the required pieces beforehand, I think....
I am not familiar with mySQL, but other threads talk about setting up mySQL tables during the install, but this was not mentioned in the Ubuntu install docs.
Thanks,
Rod
cordel
Post by cordel »
What documentation did you follow?
If we know what was done vs what was not, seeing the procedure you used would help us to give you more guidance.
Also you might want to check the users table and make sure a user actualy got populated.
Regards,
Corey
wmoore
Post by wmoore »
Are your browser cookies enabled? I tested. If cookies are not accepted, the behavior is as you described.
-WAM
