Goodday,
i have 2x 4port Capture Card but running Zoneminder
i cant see Colour from the Camera Monitor i have chosen 24 bit colour bot the video monitor turns red and stays red
Tested in xawtv tested fine very crisp and clear 24 bit colour video stream..
any ideas?
Camera with Colour
If it works in b/w and not colour i would suggest your capturing at a highish res ie 640x480. Try dropping to 320x240 and see if that helps if so you need to incresed your shared mem. Do a search for shared mem. Also check your logs as that will tell you whats wrong too
James Wilson
Thank you James Wilson
That was exatly what the problem was i ran the command
and all was well
JuanWelthagen
echo 134217728 >/proc/sys/kernel/shmmax
JuanWelthagen
