zmc segmentation fault on debian sarge
techside
Post by techside »
I have compiled source and installed all requirements.
I use a network vivotek cam through a http://xxx.xxx.xxx.xxx/cgi-bin/video.jpg network snapshot
I have created a monitor with remote option and a user:pwd@xxx.xxx.xxx.xxx parameters
When I start zone minder zmc crashed.
If I launch "zmc -m 1" i have a segmentation fault message.
BackTrace of zmc:
#0 0xb7bef9b0 in mallopt () from /lib/tls/libc.so.6
#1 0xb7beec43 in malloc () from /lib/tls/libc.so.6
#2 0xb7d702fe in operator new () from /usr/lib/libstdc++.so.5
#3 0xb7d7042f in operator new[] () from /usr/lib/libstdc++.so.5
#4 0x0804d908 in Polygon (this=0xbffff600, p_n_coords=2, p_coords=0xdb1c498) at zm_poly.cpp:55
#5 0x08056d0a in Zone::ParsePolygonString (poly_string=0xbffff600 "\002", polygon=@0x1) at zm_zone.cpp:768
#6 0x080573e2 in Zone::Load (monitor=0xdac8620, zones=@0xbffff86c) at zm_zone.cpp:873
#7 0x080653fc in Monitor::Load (id=1, load_zones=true, purpose=CAPTURE) at zm_monitor.cpp:1567
#8 0x0804ade3 in main (argc=4, argv=0x1) at zmc.cpp:175
The /tmp/zmdc.log:
03/11/06 16:30:22.863098 zmdc[18472].INF ['zmfilter.pl' started at 06/03/11 16:30:22]
03/11/06 16:30:22.870328 zmdc[18433].INF ['zmfilter.pl' starting at 06/03/11 16:30:22, pid = 18472]
03/11/06 16:30:23.212599 zmdc[18477].INF ['zmaudit.pl -c' started at 06/03/11 16:30:23]
03/11/06 16:30:23.216268 zmdc[18433].INF ['zmaudit.pl -c' starting at 06/03/11 16:30:23, pid = 18477]
03/11/06 16:30:23.479179 zmdc[18484].INF ['zmwatch.pl' started at 06/03/11 16:30:23]
03/11/06 16:30:23.485224 zmdc[18433].INF ['zmwatch.pl' starting at 06/03/11 16:30:23, pid = 18484]
03/11/06 16:30:23.731066 zmdc[18490].INF ['zmupdate.pl -c' started at 06/03/11 16:30:23]
03/11/06 16:30:23.733193 zmdc[18433].INF ['zmupdate.pl -c' starting at 06/03/11 16:30:23, pid = 18490]
03/11/06 16:30:24.503039 zmdc[18433].DBG ['zmupdate.pl -c' running since 06/03/11 16:30:23, pid = 18490, valid]
03/11/06 16:30:24.503127 zmdc[18433].DBG ['zmaudit.pl -c' running since 06/03/11 16:30:23, pid = 18477, valid]
03/11/06 16:30:24.503194 zmdc[18433].DBG ['zmfilter.pl' running since 06/03/11 16:30:22, pid = 18472, valid]
03/11/06 16:30:24.503257 zmdc[18433].DBG ['zmwatch.pl' running since 06/03/11 16:30:23, pid = 18484, valid]
03/11/06 16:30:24.503323 zmdc[18433].DBG ['zmc -m 4' pending at 06/03/11 16:30:27]
03/11/06 16:30:27.002540 zmdc[18433].INF [Starting pending process, zmc -m 4]
03/11/06 16:30:27.003335 zmdc[18510].INF ['zmc -m 4' started at 06/03/11 16:30:27]
03/11/06 16:30:27.004680 zmdc[18433].INF ['zmc -m 4' starting at 06/03/11 16:30:27, pid = 18510]
03/11/06 16:30:27.011894 zmdc[18433].ERR ['zmc -m 4' crashed, exit status 255]
03/11/06 16:30:37.010021 zmdc[18433].INF [Starting pending process, zmc -m 4]
03/11/06 16:30:37.010807 zmdc[18542].INF ['zmc -m 4' started at 06/03/11 16:30:37]
03/11/06 16:30:37.011154 zmdc[18433].INF ['zmc -m 4' starting at 06/03/11 16:30:37, pid = 18542]
03/11/06 16:30:37.019361 zmdc[18433].ERR ['zmc -m 4' crashed, exit status 255]
Use of uninitialized value in numeric ne (!=) at /usr/local/share/perl/5.8.4/ZoneMinder/SharedMem.pm line 247.
Use of uninitialized value in concatenation (.) or string at /usr/local/share/perl/5.8.4/ZoneMinder/SharedMem.pm line 255.
03/11/06 16:30:53.731707 zmdc[18598].INF ['zmc -m 4' started at 06/03/11 16:30:53]
03/11/06 16:30:53.737121 zmdc[18433].INF ['zmc -m 4' starting at 06/03/11 16:30:53, pid = 18598]
03/11/06 16:30:53.740136 zmdc[18433].ERR ['zmc -m 4' crashed, exit status 255]
Any idea ?
Thankyou
Fabio.
techside
Post by techside »
Sorry this is system details:
kernel -> 2.6.11.10
OS: Linux Debian Sarge 3.1r1
compiler: gcc version 3.3.5 (Debian 1:3.3.5-13)
Thanks.
Fabio
zoneminder
Site Admin
Post by zoneminder »
Somehow or other you appear to have a zone with only two coordinates. This usually only occurs as a result of an upgrade where the db update was missed out. Can you edit and/or reset your zones for that camera?
Phil
yakermalo
Post by yakermalo »
if you have compiled zm, specially, you could have problems with perl modules and some of the libraries, that came into conflict, we have updated perl modules, and the problen has been fixed
