Video Size
cupido
Video Size
Post by cupido »
i have installed Zoneminder 1.22 on Suse 10.0 and it works.
When i create a Video in Events then the size goes not over 15 MB. :?:
How can change this setting?
Thank you for a amswer.
Cupido
jameswilson
Post by jameswilson »
im sorry mate but i dont understand the question, if you mean the file sizes are to big after creating the video i assume you are capturing at a high framerate or high res. You Can change to options that ffmpeg uses but i dont know what to. If you goto the ffmpeg site you can download the manual
James Wilson
cupido
Video size?
Post by cupido »
I would like to prepare a mpeg file from the jpgs. Making over Events > video.
There I then select the format and choose video produce. ZM then produces one mpeg file from the jpg's. However, he goes no more than 15 MB and stops in this place.
Where I can for it make the attitude I can make a bigger video?The ffmpeg isn't in the Internet the size limited
The many thanks for answer
Greeting
Cupido
jameswilson
http://ffmpeg.sourceforge.net/ffmpeg-doc.html
above is the link to the ffmpeg docs
James Wilson
