i have zm setup on a debian box with 2 4 port cards and 5 cams. everything seems to function wonderfully except the video generation portion. the following is the version of ffmpeg i am using along with an excerpt from the zmvideo.log file with the issue i am having.
fIWRKZzm:/var/log/zm# ffmpeg --version
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --prefix=/usr --libdir=${prefix}/lib --enable-shared --enable-mp3lame --enable-gpl --enable-faad --mandir=${prefix}/share/man --enable-vorbis --enable-pthreads --enable-faac --enable-xvid --enable-dts --enable-amr_nb --enable-amr_wb --enable-pp --enable-shared-pp --enable-libogg --enable-a52 --enable-a52bin --enable-x264 --enable-theora
built on Dec 30 2005 15:07:33, gcc: 3.3.5 (Debian 1:3.3.5-13)
ffmpeg: missing argument for option '--version'
IWRKZzm:/var/log/zm# tail -f zmvideo.log
Duration: 00:14:45.2, start: 0.000000, bitrate: N/A
Stream #0.0, 5.00 fps: Video: mjpeg, yuvj420p, 320x480
Output #0, mpeg, to 'Event-921.mpg':
Stream #0.0, nan fps: Video: mpeg1video, yuv420p, 320x480, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0xb7ea0110]MPEG1/2 does not support 5/1 fps
Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Error: 1 at /usr/bin/zmvideo.pl line 277.
