Ok, I checked the box that said to authenticate users and ASSUMED it was checking against the regular login I created during the install or root with password but thee don'w work.... So what do I do????
I see maybe these users need to be defined in MYSQL??? But I havent a clue on how to do that....
Ken
OHHHH CRAP HELP!!!!!!!!!!!!!!!!!!!!!
aha ken we meet again lol
try admin and admin
**edit
ps in the readme its in section 8 the tutorial if i recall
try admin and admin
**edit
James Wilson
Thanks, How doyou change the admin
How do you change the default admin password and maybe eventhe username??
assuming you can log in now?
If you goto options then the last tab on the far right should be users, you can edit and add in here matey!
James Wilson
Ok, I got the username thing.... But there is a few probs.
Ok, 2 BIG issues,,,
Over the last day or 2 I installed this program on another machine for my Brothers business, using different everything and again, when I open the windows viewer I get these wierd issues with the error and the resizing and moving of windows. This is 3 machines, and ALL are doing the same exact thing.... Only thing in common is Windows XP as a client PC...
Next even bigger issue though, On the first installation, when I go into the webpage to run this software and I click on video it KILLS my ethernet connection and the only way to get it back it to reset machine. Anyone else having this problem??? I have un-instaled and re-installed the JAVA with the latest version and also have all the XP client files updated via microsoft update. 2 machines BOTH doing this.... Weirdness....
Ken
Ken
cant help on the second issue as i havnt had that
1st issue?
I am about to post an interim update as i really cant replicate this but i am using the version i mess with so i may have a way different version to you, give me about an hour mate! Sorry i will get it sorted. As previous if anyone else is having this it would be nice to hear your experiences!
1st issue?
James Wilson
Thanks James
I will try to continue to post as much information on this as I can. Here is what I strongly suspect but can't quite put my finger on it. Multiple windows over 4 seem to cause a problem... I have tried many different configurations and saved a couple formats... Then I exited the program and re-entered and ran it and within about 4 minutes it started generating the error. I then ran it standard 4 window and it seemed to work fine??
Please send the link and I can try the other version since I can replicate this VERY easily and get it to fail almost without effort.
Thanks,
Ken
Thanks,
Ken
ken if you follow the original link you had it should download the newset version mate
James Wilson
