Unable to login authenticated mode
martrw
Post by martrw »
Using 1.21.4, reinstalled after failed upgrade to 1.22.0. Uninstalled all 1.22.0 files I could locate.
1.21.4 ran well prior to upgrade. During install from binary, database zm/users was not populated with admin:admin user. Manually added both admin:admin and rob:password to zm/users database. Stop/Start zmpkg.pl. Cannot log in to Zoneminder after making these changes.
I am typing the password directly into the password field in the users database.
Copy and paste from Webmin interface to zm/users table below:
admin admin en_gb 1 View Edit Edit Edit Edit Low Camera1
Help Please... Rob
jameswilson
Post by jameswilson »
i dont know how to fix that but if you need to get in you could turn off auth mode temorarily from webmin
James Wilson
martrw
Post by martrw »
James
Been turning it on and off using zmconfig.pl, but that is not how I wanted to use this package.
Thanks... Rob
zoneminder
Site Admin
Post by zoneminder »
The password in the DB is not the raw password. You need to set it as follows
update Users set Password = password( "admin" ) where...
rather than just Password = "admin".
Phil
martrw
Post by martrw »
Thanks... now I know.
I ended up going in the backdoor. I finally got admin/admin up, but without system privilidges, so I couldn't add additional users.
Since I could get to the DB through Webmin, I copy/pasted the admin coded password to user "rob" and gave myself all privildges. Update Options from ZoneMinder and I'm up and running again... finally.
Excellent program... there needs to be a "ZoneMinder for Dummies" text.
