problem with login
vizzio
problem with login
Post by vizzio »
i have one problem with login..
I do not understand like making the login, why I have not created no users.
zoneminder
Site Admin
Re: problem with login
Post by zoneminder »
I'm not sure I understand your question exactly but if you are asking why you get a login prompt when you have not made any users yourself, there is a default user with the username 'admin' and password 'admin'. Or you can unset ZM_OPT_USE_AUTH and then you don't need to log in at all.
Phil,
wcchiou
Is there a chance to create my own username and password
Post by wcchiou »
Hi Zoneminder:
Thanks for your giving us such a great program for use.
I am wondering is it possible to create my own username and password instead of the default admin/admin.
Thanks a lot for your help.
zoneminder
Site Admin
Yes, go to Options->Users and add or edit as you like.
Phil
