I'm exhausted from creating the control script for the PTZ2N, but that's no excuse for not figuring this one out:
Does ZM emit -move_map control commands when you click on a monitor image? I want to be able to click on the image and have ZM center the click point by panning and tilting.
What I've found so far is that the move_map commands are used for the motion tracking feature - I haven't been able to make ZM emit anything from a click on the image.
Does ZM even do that? Is it cambozola-related? Or browser related? I've tried a number of things, but nothing has worked so far.
Sorry if ZM already does this - I couldn't find it anywhere in the forums...
Thanks in advance.
Mapped motion from Monitor click
I think zm does this or it did in 1.21.3 but you need to use firefox
James Wilson
- zoneminder
- Site Admin
- Contact:
Here are the possible settings that affect the Watch window HTML code:
ZM:
1) use cambozola.
2) browser detection.
3) javascript vs. http switch.
Browser:
1) IE vs. Netscape vs. Firefox
2) Streaming capability.
So my current questions are:
1) Does the monitor window map-clicking work if the page is javascript?
2) Does the monitor window map-clicking work if the page is pure html?
3) Do Netscape or Firefox ever get any html content that's non-javascript (e.g. do they ever see the cambozola java code)?
4) Does Browser native streaming/display affect whether you can map-click.
I'm asking because I've tried the three browsers, and although they get different pages to display, IE gets cambozola, and the other two get only javascript. Changing the options in ZM doesn't seem to change what each browser gets sent. And so far, *nothing* makes ZM emit any move_map_* commands.
I'm still at it, though...
It's a burning question because I now have two control scripts for two cameras - one that *can* read back the camera's PT position, and another that *can't*. So, when I can make the map-clicking work, I'll have the two different types of control code to create - one with no saved state information, and one with saved state information.
And then...I can start trying out all kinds of cameras that don't have control scripts...
ZM:
1) use cambozola.
Browser:
- zoneminder
- Site Admin
- Contact:
I'm quickly learning what I need to know about shared memory.
Then, the control script would *either* check for SHM,
create it if it's not there (first call),
move the camera to a known position (reset or to the stop and back),
and store the various axes' positions there.
*or*
Run using the stored positions.
I suppose you could do it to disk, but each control click would be a read/write.
*or*
- zoneminder
- Site Admin
- Contact:
