so far I have (nearly) no problems with Zoneminder but when I use zmu -l it gives me a segmentation fault after the first monitor (out of two) and also zmu -m 2 -q (2 is my first monitor) gives me a segmentation fault after printing out the informations about the last zone. As everything works fine I don't know if this indicates a serious problem or only a minor bug somewhere. Any ideas?
Helge.
sfu2-server:/tmp# zmu -m 2 -q
Type : Remote
Host : 192.168.2.200
Port : 80
Path : /IMAGE.JPG
Width : 640
Height : 480
Palette : 4
Colours : 3
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 50
Warmup Count : 15
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 5.00
Reference Blend %ge : 15
Track Motion : 0
Function: 3 - Motion Detection
Zones : 3
Label : All
Type: 1 - Active
Alarm RGB : ff0000
Check Method: 1 - Alarmed Pixels
Min Pixel Threshold : 10
Max Pixel Threshold : 0
Min Alarm Pixels : 15360
Max Alarm Pixels : 0
Filter Box : 5,5
Min Filter Pixels : 0
Max Filter Pixels : 0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
Label : New
Type: 5 - Inactive
Alarm RGB : 000000
Check Method: 0 - Unknown
Min Pixel Threshold : 0
Min Alarm Pixels : 0
Filter Box : 0,0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 0
Max Blobs : 0
Label : New
Type: 5 - Inactive
Alarm RGB : 000000
Filter Box : 0,0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 0
Max Blobs : 0
Speicherzugriffsfehler
