ZM 1.19 remote camera not showing image, no events in dir...
Building a new system with 1.19. Looks like everthing built correctly but my logs are
/var/log/messgages
2 16:32:01 linux zmc-m3[2567]: INF [Starting Capture]
Mar 22 16:32:02 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:03 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:03 linux zmc-m3[2567]: ERR [Select timed out]
Mar 22 16:32:04 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:05 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:05 linux zmc-m3[2567]: ERR [Select timed out]
Mar 22 16:32:06 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:06 linux zms[2580]: INF [Debug Level = 0, Debug Log = ]
Mar 22 16:32:07 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:07 linux zmc-m3[2567]: ERR [Select timed out]
Mar 22 16:32:08 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:09 linux zma-m3[2519]: WAR [Waiting for capture daemon]
Mar 22 16:32:09 linux zmc-m3[2567]: ERR [Select timed out]
/tmp/zmdc.log
'zmfilter.pl -e -1' starting at 04/03/22 16:32:21, pid = 2584
Can't locate MIME/Entity.pm in @INC (@INC contains: /usr/lib/perl5/5.8.1/i586-l$
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 87.
'zmfilter.pl -e -1' crashed at 04/03/22 16:32:21, exit status 2
Starting pending process, zmfilter.pl -e -1
'zmfilter.pl -e -1' started at 04/03/22 16:33:41
'zmfilter.pl -e -1' starting at 04/03/22 16:33:41, pid = 2606
'zmfilter.pl -e -1' crashed at 04/03/22 16:33:41, exit status 2
It's a SUSE 9.0 box if that makes any difference.
/var/log/messgages
/tmp/zmdc.log
Re: ZM 1.19 remote camera not showing image, no events in di
you need some perl modules like mime::entity
Ok got Perl Mods,
Still no pictures or events captured.
/var/log/messages
Mar 23 10:22:26 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:27 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:28 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:28 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:29 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:30 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:30 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:31 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:32 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:32 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:33 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:34 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:34 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:35 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:36 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:36 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:37 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:38 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:38 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:39 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:40 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:40 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:41 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:42 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:42 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:43 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:44 linux zma-m3[6559]: WAR [Waiting for capture daemon]
Mar 23 10:22:44 linux zmc-m3[6555]: ERR [Select timed out]
Mar 23 10:22:45 linux zma-m3[6559]: WAR [Waiting for capture daemon]
/tmp/zmdc
Server starting at 04/03/23 10:17:47
'zmc -m 3' started at 04/03/23 10:17:50
'zmc -m 3' starting at 04/03/23 10:17:50, pid = 6555
'zma -m 3' started at 04/03/23 10:17:50
'zma -m 3' starting at 04/03/23 10:17:50, pid = 6559
'zmfilter.pl -e -1' started at 04/03/23 10:17:50
'zmfilter.pl -e -1' starting at 04/03/23 10:17:50, pid = 6563
'zmaudit.pl -d 900 -y' starting at 04/03/23 10:17:51, pid = 6567
'zmaudit.pl -d 900 -y' started at 04/03/23 10:17:51
'zmwatch.pl' started at 04/03/23 10:17:51
'zmwatch.pl' starting at 04/03/23 10:17:51, pid = 6572
'zmupdate.pl -c' started at 04/03/23 10:17:51
'zmupdate.pl -c' starting at 04/03/23 10:17:51, pid = 6577
Not a JPEG file: starts with 0x0d 0x0a
'zmc -m 3' crashed at 04/03/23 10:23:07, exit status 1
'zmc -m 3' started at 04/03/23 10:23:07
'zmc -m 3' starting at 04/03/23 10:23:07, pid = 6691
'zmc -m 3' crashed at 04/03/23 10:23:41, exit status 1
Starting pending process, zmc -m 3
'zmc -m 3' started at 04/03/23 10:23:46
'zmc -m 3' starting at 04/03/23 10:23:46, pid = 6693
'zmc -m 3' crashed at 04/03/23 10:24:41, exit status 1
'zmc -m 3' started at 04/03/23 10:24:51
'zmc -m 3' starting at 04/03/23 10:24:51, pid = 6695
'zmc -m 3' crashed at 04/03/23 10:24:53, exit status 1
'zmc -m 3' started at 04/03/23 10:25:13
'zmc -m 3' starting at 04/03/23 10:25:13, pid = 6697
'zmc -m 3' crashed at 04/03/23 10:25:14, exit status 1
My other test system with an older version of ZM works fine. Any suggestions would help. THX
/var/log/messages
/tmp/zmdc
Ok got Perl Mods,
/var/log/messages
/tmp/zmdc
/var/log/messages
/tmp/zmdc
Ok got Perl Mods,
/var/log/messages
/tmp/zmdc
/var/log/messages
/tmp/zmdc
- zoneminder
- Site Admin
- Contact:
Hi Scott,
Have you tried with the pre-release 1.19.1? I think that might help you. Which camera do you have by the way?
Phil,
Phil,
Have Dlink DCS-1000
I'll try 1.19.1.
Here is some info I found about this error, looking like a possible 1.19.0 bug
http://www.frogtown.com/pipermail/motio ... d.html#381
http://www.frogtown.com/pipermail/motio ... d.html#382
I'll try 1.19.1.
Have Dlink DCS-1000
I'll try 1.19.1.
I'll try 1.19.1.
Have Dlink DCS-1000
I'll try 1.19.1.
I'll try 1.19.1.
Excuse the double post:
OK 1.91.1 shows
zmdc:
Server starting at 04/03/23 14:05:01
'zmc -m 1' started at 04/03/23 14:05:04
'zmc -m 1' starting at 04/03/23 14:05:04, pid = 2227
'zma -m 1' started at 04/03/23 14:05:04
'zma -m 1' starting at 04/03/23 14:05:04, pid = 2231
'zmfilter.pl -e -1' started at 04/03/23 14:05:05
'zmfilter.pl -e -1' starting at 04/03/23 14:05:05, pid = 2235
'zmaudit.pl -d 900 -y' starting at 04/03/23 14:05:05, pid = 2239
'zmaudit.pl -d 900 -y' started at 04/03/23 14:05:05
'zmwatch.pl' started at 04/03/23 14:05:05
'zmwatch.pl' starting at 04/03/23 14:05:05, pid = 2244
'zmupdate.pl -c' started at 04/03/23 14:05:05
'zmupdate.pl -c' starting at 04/03/23 14:05:05, pid = 2249
'zmc -m 1' died at 04/03/23 14:05:34, signal 10
'zmc -m 1' started at 04/03/23 14:05:34
'zmc -m 1' starting at 04/03/23 14:05:34, pid = 2270
'zmc -m 1' died at 04/03/23 14:06:03, signal 10
Starting pending process, zmc -m 1
'zmc -m 1' started at 04/03/23 14:06:08
'zmc -m 1' starting at 04/03/23 14:06:08, pid = 2318
'zmc -m 1' died at 04/03/23 14:06:10, signal 10
'zmc -m 1' started at 04/03/23 14:06:20
'zmc -m 1' starting at 04/03/23 14:06:20, pid = 2336
'zmc -m 1' stopping at 04/03/23 14:06:46
'zmc -m 1' died at 04/03/23 14:06:49
Use of uninitialized value in hash element at /usr/local/bin/zmdc.pl line 332, <CLIENT> line 1.
'zmc -m 1' started at 04/03/23 14:07:09
'zmc -m 1' starting at 04/03/23 14:07:09, pid = 2400
'zmc -m 1' stopping at 04/03/23 14:07:59
'zmc -m 1' died at 04/03/23 14:08:05, signal 8
'zmc -m 1' started at 04/03/23 14:08:15
'zmc -m 1' starting at 04/03/23 14:08:15, pid = 2504
'zmc -m 1' stopping at 04/03/23 14:08:35
'zmc -m 1' died at 04/03/23 14:08:41
'zmc -m 1' started at 04/03/23 14:09:01
'zmc -m 1' starting at 04/03/23 14:09:01, pid = 2524
'zmc -m 1' stopping at 04/03/23 14:09:52
ar 23 14:10:17 linux zmc-m1[2554]: INF [Starting Capture]
Mar 23 14:11:07 linux zmc-m1[2554]: INF [Got TERM signal, exiting]
Mar 23 14:11:07 linux zmc-m1[2554]: ERR [Can't connect to remote camera: Interrupted system call]
Mar 23 14:11:31 linux zmc-m1[2560]: INF [Debug Level = 0, Debug Log = ]
Mar 23 14:11:31 linux zmc-m1[2560]: INF [Starting Capture]
Mar 23 14:11:33 linux zmc-m1[2560]: ERR [Select timed out]
Mar 23 14:11:35 linux zmc-m1[2560]: ERR [Select timed out]
Mar 23 14:11:35 linux zms[2567]: INF [Debug Level = 0, Debug Log = ]
Mar 23 14:11:37 linux zmc-m1[2560]: ERR [Select timed out]
Mar 23 14:12:02 linux zmc-m1[2560]: ERR [Select timed out]
Mar 23 14:12:21 linux zmc-m1[2560]: INF [Got TERM signal, exiting]
Mar 23 14:12:21 linux zmc-m1[2560]: ERR [Can't connect to remote camera: Interrupted system call]
Mar 23 14:12:44 linux zmc-m1[2739]: INF [Debug Level = 0, Debug Log = ]
Mar 23 14:12:44 linux zmc-m1[2739]: INF [Starting Capture]
Mar 23 14:12:47 linux zmc-m1[2739]: ERR [Select timed out]
Mar 23 14:12:49 linux zmc-m1[2739]: ERR [Select timed out]
Mar 23 14:13:04 linux zmc-m1[2739]: INF [Got TERM signal, exiting]
Mar 23 14:13:04 linux zmc-m1[2739]: ERR [Can't connect to remote camera: Interrupted system call]
Mar 23 14:13:20 linux zmc-m1[2841]: INF [Debug Level = 0, Debug Log = ]
Mar 23 14:13:20 linux zmc-m1[2841]: INF [Starting Capture]
Mar 23 14:13:22 linux zmc-m1[2841]: ERR [Select timed out]
Looks like thier are some timeout issues. but I have a 0.9.16 that seems to be working much better.
So far 1.19.1 only shows .33 fps and 9.16 showing 3 fps same exact camera and IP.
OK 1.91.1 shows
zmdc:
- zoneminder
- Site Admin
- Contact:
Hi Scott,
Have you tried using video.cgi instead of IMAGE.JPG in the monitor path settings? This should be much quicker and get you maybe 10fps instead of 1fps if your DCS-1000 is anything like my DCS-1000W. I don't know of any reason why 1.19.1 should be any slower with the existing path though, it's not like either version is actually doing anything for 95% of the time it's just waiting. The only that that might effect it is the timeout setting in zmwatch.pl.
Anyway, see of the mJPEG url works better for you.
Phil,
Phil,
Ahh,
video.cgi works much better. Getting about 3.33 fps. Any other setting to try?
