Video creation problem on debian sarge - pl
maciekc
Post by maciekc »
There is a problem in creating video files.
This patch changes %.2f to%.2F in sprintf this will make it work on every localized system - there will be always "." instead of ",". "," makes ffmpeg to end with an error instead of making video file.
Please consider changing this in next release. It would make zm more compatible.
--- /root/ZoneMinder-1.22.0/web/zm_funcs.php 2006-01-17 22:11:49.000000000 +0100
+++ /var/www/zm_funcs.php 2006-03-25 23:47:19.868363880 +0100
@@ -1016,7 +1016,7 @@
function createVideo( $event, $format, $rate, $scale, $overwrite=false )
- $command = ZM_PATH_BIN."/zmvideo.pl -e ".$event['Id']." -f ".$format." -r ".sprintf( "%.2f", ($rate/RATE_BASE) )." -s ".sprintf( "%.2f", ($scale/SCALE_BASE) );
+ $command = ZM_PATH_BIN."/zmvideo.pl -e ".$event['Id']." -f ".$format." -r ".sprintf( "%.2F", ($rate/RATE_BASE) )." -s ".sprintf( "%.2F", ($scale/SCALE_BASE) );
if ( $overwrite )
$command .= " -o";
$result = exec( $command, $output, $status );
cordel
Post by cordel »
Thank you for this :)
Regards,
Corey
zoneminder
Site Admin
Post by zoneminder »
I have added this fix into 1.22.1, though %F is only supported for php 4.3.10 and later so the fix will only function for systems that meet this critierion.
Phil
maciekc
Post by maciekc »
OK thanks for adding my fix. Would be useful for me.
