alarm fps
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
jameswilson
alarm fps
Post by jameswilson »
just a thought
I haved used ignore max fps with succes on the single chip capture cards but causes no end of grief with a few ip cams.
Could it be changed to
normal fps
alarm fps
and still have ignore max on alarm. I would then use 1 fps normally (or even 0.5) and have alarm at 4 fps. I currently do this but i use a feamseskip and this uses cycles to analyse when nothing is happening
James Wilson
zoneminder
Site Admin
Post by zoneminder »
Are you using just jpeg sources with your IP cams? Otherwise the FPS is controlled by the cam anyway so whatever ZM does will have no effect.
Phil
jameswilson
yes i am using jpg sourcses. maybe a ignore fps max setting could be done as a global, so if i wanted to ignore the 1 fps used but limit it to 5, thecreason im having a problem is if multiple ip cams alarm together as the machine cannot handle it
James Wilson
zoneminder
Site Admin
I have added this to the feature queue!
Phil
jameswilson
cheers mate, btw how long is the feature list
James Wilson
zoneminder
Site Admin
Pretty long, the bug/feature numbers are up to about 300 or so. However I have found some time today to implement this and add an Alarm Max FPS setting to each monitor so the maximum FPS during alarm is now set on a monitor basis rather than globally.
Will that do?
Phil
