email not working in ZM
antar
Post by antar »
I get the below msg in the log. i have an SMTP defined and NET:SMTP is installed and so is MIME::Lite
Use of uninitialized value in pattern match (m//) at /usr/local/bin/zmfilter.pl line 755.
Use of uninitialized value in pattern match (m//) at /usr/local/bin/zmfilter.pl line 770.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 795.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 796.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 797.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 798.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 799.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 800.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 801.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 802.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 803.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 804.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 805.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 806.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 807.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 808.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 809.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 810.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 811.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 812.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 813.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 814.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 815.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 816.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 817.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 818.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 819.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 858.
Use of uninitialized value in substitution (s///) at /usr/local/bin/zmfilter.pl line 860.
cordel
Post by cordel »
Looks like you might be missing something in your definitions in your mail syntax. Check your definitions and make sure you have all the syntax correct.
Regards,
Corey
antar
Post by antar »
issue solved with this
from another posting
The problem turned out to be that the default value of ZM_EMAIL_TXT is missing a double quote (") at the end of it. This results in $email_subject and $email_body not being set because the initialization statement in zmfilter.pl fails:
( $email_subject, $email_body ) = ZM_EMAIL_TEXT =~ /subject\s*=\s*"([^\n]*)".*body\s*=\s*"(.*)"/ms;
Adding the closing quote to fixed this. I checked the zm_create.sql script and confirmed that it's missing. It's also missing from ZM_MESSAGE_TXT too but I'm not using that yet."
cordel
Post by cordel »
I remember something about that now that you mention it. Glad you got it going.
Cheers,
Corey
Maxxer
Post by Maxxer »
antar wrote:( $email_subject, $email_body ) = ZM_EMAIL_TEXT =~ /subject\s*=\s*"([^\n]*)".*body\s*=\s*"(.*)"/ms;
I have this exact line in zmfilter.pl (ZM 1.22.0) but it's not sending emails. zmfilter log just says it's going to create the mail but then nothing happens.
Did I miss something?
