zmc_m1 (or m2, or m3) WAR: unable to use netcam regexps as not compiled with libpcre
Is this warning related with no images in monitors (but images available in "zones"
definition tab)?
Thank you
Roberto
zm log warning .. related with no image ?
no, not related...
Now libpcre.a is installed, I have no warnings in /var/log/messages
but can see only the image placeholder in monitor.
Very odd, since I get the image inside the zone defintion panel.
I tried various axis presets for the monitor...
Again, any idea on how to debug this situation ?
Roberto
Roberto
Thanks Corey.
no errors in apache, but I can give some more detailed report:
The relevant part of the html source in the monitor window which should display the image (monitor id=3) is:
http://130.186.7.229/cgi-bin/nph-zms?mo ... 1143710841
The above line does not work as a stand alone url in the browser: it looks like nph-zms is not recognized
as a cgi script and apache raise the popup"whta should I do with nph-zms which is a BIN file"
But the odd thing is that if I cut the "&monitor=3" string I get the cgi recognized and get this output:
Server: ZoneMinder Video Server/1.22.0
Expires: Mon, 26 Jul 1997 05:00:00 GMT
Last-Modified: Thu, 30 Mar 2006 09:44:07 GMT
Cache-Control: no-store, no-cache, must-revalidate
Cache-Control: post-check=0, pre-check=0
Pragma: no-cache
Any of the parameters after ? is not offending apache, but monitor= does.
Is it a parse problem ?
Apache is 1.3.34 / Debian
Any Idea ?
I will try with a previous version of zm and give a feedback....
Robert
Pragma: no-cache
Any Idea ?
Robert
