Hi.
Phil and others, i just cant set jpeg quality.
i have set it up in the Database to 40, but no difference on the images... same size and quality. ive restarted and nothing changes.
Is there a way to get it work ?
Another bad thing is when in record mode, when you click "per-frame" mode, all you can see is the first line. all lines under first are showed as corrupted link, because it appoints to 000-capture.jpg not to the right 005, 006 etc.
But when watching the continuous mode all goes ok.
Modect mode works well even in "per-frame" mode.
Any idea on how to solve any of them ?
My best regards and thanks in advance
Victor Diago
jpeg quality 2 - the mission
- victor_diago
- Contact:
i think there is another thread about jpeg quality and someone posted an edit. I cant get it to change either from editing the db but im gonna wait till 1.22.1 arrives rather than apply patches
James Wilson
- victor_diago
- Contact:
Yes this is to fix that problem. If you can't use the patch program, it's easy to make the changes manually. The patch is only 3 lines.
The lines with the"@" are the approximate line numbers in zm_image.cpp.
Just type in the lines that are preceded with a "+" and delete the line that is preceded with a "-".
You still have to make the changes to the database manually as you have been doing.
thanks
tommy
thanks
tommy
- zoneminder
- Site Admin
- Contact:
