I have recently solved a frame rate problem that I had with a AXIS 205 and 206w cameras.
I am running the latest LiveCD (v1.21.3).
I have run across a couple of issues that I need solving.
The first is when i try and view the live stream from within ZM. I get the first frame and it is VERY blocky (example below). Just to note, it does do motion detection and I can view the events without too many problems (one issue detailed below).
The second problem I have is that although I have turned the compression down low on my camera the picture when I am viewing events is really blocky as well (like above).
Any ideas?[/img]
