new detection methods...
first i have to say ... new is more easy to set detection filters...
wen i use filtered i get some weird analysed files..
<img src="http://cablemodem.fibertel.com.ar/campo ... nalyse.jpg" width="320" height="240">
this is normal? and idea is to see by default the captured frames and the link to see the analized ones.
- zoneminder
- Site Admin
- Contact:
Re: new detection methods...
Hi Fernando,
This looks like a debug image rather than a proper analyse image. When you say new 'detection filters' what/where exactly do you mean?
Phil,
Phil,
in alarmedpixels i get this frame .
why dont use dont show by default the captured file.. and a link the alarmed file is this is available
some times you need the captured file cus the alarmed file is filled whith red lines. :)
- lazyleopard
I get those "debug" images in place of the alarmed-overlay stills sometimes. There doesn't seem to be an obvious logic to it though. Sometimes they appear, sometimes I get the correct overlay image instead. It does seem to happen (I think) only when multiple zones are defined, though.
- zoneminder
- Site Admin
- Contact:
I will look into this. Are you running with diagnostic images enabled? If so you will probably be crippling your performance by the way. I would only use it briefly to investigate settings or what triggers thing etc.
Phil,
Phil,
- zoneminder
- Site Admin
- Contact:
Also what 'check method' are your zones set up to use?
in mi case i set "Alarm Check Method" "alarmedpixels" and has you see in the picture.. the zone is that small rectangle in the upper right.
i dont have diagnostic images enabled..
- zoneminder
- Site Admin
- Contact:
Yes, I've found and fixed a bug. If you use a check method other than blobs then you won't get edge highlighting for that zone as there are no blobs so there are no obvious edges to highlight. However the code wasn't clearing out the images so it thought that there was an analysis image to write. The fix corrects this (or should when I've tested it) so that you won't get any analysis images written unless at least one of your zones has 'blobs' as a check method and is alarmed.
Phil,
Phil,
- lazyleopard
ZM_CREATE_ANALYSIS_IMAGES and ZM_RECORD_EVENT_STATS are checked, but ZM_RECORD_DIAG_IMAGES is not. I've got 7 zones defined. Two are Active and two are Inclusive, all using blobs. The remaining three are Inactive.
- zoneminder
- Site Admin
- Contact:
Hi Rick,
There is a bugette I've found which may be responsible for this. It will be in the next version or I can probably do a patch if you want one.
Phil,
Phil,
- lazyleopard
Now that jpeg streaming is working again I can live with a few broken analysis images for a while, thanks. I'll wait for the next revision.
- lazyleopard
With 1.19.2 I'm still occasionally seeing 'debug' images in place of analysed images, but so far I've not spotted a pattern.... It's most obvious on my grey-scale camera when parts of the image within an active zone get marked all-white, and all parts of the image not in any zone get left black. I'm using 'Blobs' for analysis.
Rick Hewett
