This is the output of "dmesg |grep bttv":
Any ideas?[root@localhost dadaniel]# dmesg |grep bttv bttv: driver version 0.9.15 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Host bridge needs ETBF enabled.
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 2) at 0000:00:0a.0, irq: 5, latency: 32, mmio: 0xe2000000
bttv0: detected: (Askey Magic/others) TView99 CPH06x [card=38], PCI subsystem ID is 144f:3000
bttv0: using: Askey CPH06X TView99 [card=38,autodetected]
bttv0: enabling ETBF (430FX/VP3 compatibilty)
bttv0: gpio: en=00000000, out=00000000 in=00ffefff [init]
bttv0: using tuner=1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv0: add subdevice "remote0"
bttv0: PLL can sleep, using XTAL (28636363).
