Shared Memory problem
sick347
Post by sick347 »
I seem to be having a shared memory problem even though I altered the sysctl.conf as follows:
frank@wdshss:/etc> cat sysctl.conf
# Disable response to broadcasts.
# You don't want yourself becoming a Smurf amplifier.
# enable route verification on all interfaces
# enable ipV6 forwarding
#net.ipv6.conf.all.forwarding = 1
kernel.shmall = 134217728
kernel.shmmax = 134217728
see the error below:
04/06/06 09:00:21.701353 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:00:21.701672 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:00:21.911754 zmwatch[18932].INF ['zmc -d /dev/video0' started at 06/04/06 09:00:21] at /usr/local/bin/zmwatch.pl line 118
04/06/06 09:00:31.914826 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:00:31.915131 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:00:32.126818 zmwatch[18932].INF ['zmc -d /dev/video0' starting at 06/04/06 09:00:32, pid = 1665] at /usr/local/bin/zmwatch.pl line 118
04/06/06 09:00:42.130230 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:00:42.130551 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:00:42.343726 zmwatch[18932].INF ['zmc -d /dev/video0' started at 06/04/06 09:00:42] at /usr/local/bin/zmwatch.pl line 118
04/06/06 09:00:52.346692 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:00:52.347009 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:00:52.558360 zmwatch[18932].INF ['zmc -d /dev/video0' started at 06/04/06 09:00:52] at /usr/local/bin/zmwatch.pl line 118
04/06/06 09:01:02.561136 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:01:02.561453 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:01:02.772243 zmwatch[18932].INF ['zmc -d /dev/video0' started at 06/04/06 09:01:02] at /usr/local/bin/zmwatch.pl line 118
04/06/06 09:01:12.775585 zmwatch[18932].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/06/06 09:01:12.775902 zmwatch[18932].INF [Restarting capture daemon for Test, shared memory not valid]
04/06/06 09:01:12.986073 zmwatch[18932].INF ['zmc -d /dev/video0' started at 06/04/06 09:01:12] at /usr/local/bin/zmwatch.pl line 118
04/06/2006 21:58:45.499647 zmwatch[9449].INF [Watchdog starting]
04/06/2006 21:58:45.500542 zmwatch[9449].INF [Watchdog pausing for 30 seconds]
04/07/06 02:41:11.019538 zmwatch[11473].INF [Watchdog starting]
04/07/06 02:41:11.031621 zmwatch[11473].INF [Watchdog pausing for 30 seconds]
04/07/06 08:51:27.321354 zmwatch[32589].INF [Watchdog starting]
04/07/06 08:51:27.322015 zmwatch[32589].INF [Watchdog pausing for 30 seconds]
04/08/06 14:05:18.751231 zmwatch[11770].INF [Watchdog starting]
04/08/06 14:05:18.751925 zmwatch[11770].INF [Watchdog pausing for 30 seconds]
04/09/06 15:58:43.536960 zmwatch[7473].INF [Watchdog starting]
04/09/06 15:58:43.560754 zmwatch[7473].INF [Watchdog pausing for 30 seconds]
thanks
-frank
got my eye on you!
zoneminder
Site Admin
Post by zoneminder »
This looks like just the zmatch log, which will only be showing secondary errors. Check /var/log/messages and see if there is something more illuminating in there.
Phil
sick347
Post by sick347 »
ok I'll check it out.
The only reason I'm posting is because now ZM, even though it's "running", refuses to trigger on a motion event and just throws an alarm (in RED) under the video montage window when something is active in the cam view. It does not record the event though...
thanks
-frank
got my eye on you!
sick347
Post by sick347 »
Here is the beginning of the issue...I think
Apr 10 06:06:14 wdshss zma_m2[20159]: INF [Test2: 870000 - Processing at 29.41 fps]
Apr 10 06:06:20 wdshss zmc_dvideo3[8180]: INF [Test2: 1341000 - Capturing at 29.41 fps]
Apr 10 06:06:20 wdshss zmc_dvideo0[8176]: INF [Test: 1341000 - Capturing at 29.41 fps]
Apr 10 06:06:47 wdshss zma_m2[20159]: INF [Test2: 871000 - Processing at 30.30 fps]
Apr 10 06:06:53 wdshss zmc_dvideo3[8180]: INF [Test2: 1342000 - Capturing at 30.30 fps]
Apr 10 06:06:53 wdshss zmc_dvideo0[8176]: INF [Test: 1342000 - Capturing at 30.30 fps]
Apr 10 06:07:20 wdshss zma_m2[20159]: INF [Test2: 872000 - Processing at 30.30 fps]
Apr 10 06:07:26 wdshss zmc_dvideo3[8180]: INF [Test2: 1343000 - Capturing at 30.30 fps]
Apr 10 06:07:26 wdshss zmc_dvideo0[8176]: INF [Test: 1343000 - Capturing at 30.30 fps]
Apr 10 06:07:54 wdshss zma_m2[20159]: INF [Test2: 873000 - Processing at 29.41 fps]
Apr 10 06:07:59 wdshss zmpkg[24248]: INF [Command: stop]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmaudit.pl -c' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmaudit.pl -c' died, signal 14]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmwatch.pl ' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmwatch.pl ' died, signal 14]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmc -d /dev/video3' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmc_dvideo3[8180]: INF [Got TERM signal, exiting]
Apr 10 06:08:00 wdshss zmc_dvideo3[8180]: ERR [Sync failure for frame 5 buffer 6(1): Interrupted system call]
Apr 10 06:08:00 wdshss zma_m2[20159]: WAR [Signal Lost]
Apr 10 06:08:00 wdshss zma_m2[20159]: INF [Test2: 873175 - Gone into alarm state]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmc -d /dev/video3' died]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmupdate.pl -c' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmupdate.pl -c' died, signal 14]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmfilter.pl ' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmfilter.pl ' died, signal 14]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmc -d /dev/video0' stopping at 06/04/10 06:08:00]
Apr 10 06:08:00 wdshss zmc_dvideo0[8176]: INF [Got TERM signal, exiting]
Apr 10 06:08:00 wdshss zmc_dvideo0[8176]: ERR [Sync failure for frame 7 buffer 0(1): Interrupted system call]
Apr 10 06:08:00 wdshss zma_m2[20159]: ERR [Can't insert frames: Duplicate entry '13806' for key 1]
Apr 10 06:08:00 wdshss zmdc[8153]: ERR ['zma -m 2' crashed, exit status 38]
Apr 10 06:08:00 wdshss zmdc[8153]: INF ['zmc -d /dev/video0' died]
Apr 10 06:08:00 wdshss Use of freed value in iteration at /usr/local/bin/zmdc.pl line 557, <CLIENT> line 1.
Apr 10 06:08:58 wdshss zmpkg[24302]: INF [Command: start]
Apr 10 06:08:59 wdshss zmdc[24314]: INF [Server starting at 06/04/10 06:08:59]
Apr 10 06:09:02 wdshss zmdc[24337]: INF ['zmc -d /dev/video0' started at 06/04/10 06:09:02]
Apr 10 06:09:02 wdshss zmdc[24314]: INF ['zmc -d /dev/video0' starting at 06/04/10 06:09:02, pid = 24337]
Apr 10 06:09:02 wdshss zmc_dvideo0[24337]: INF [Debug Level = 0, Debug Log = <none>]
Apr 10 06:09:02 wdshss zmc_dvideo0[24337]: INF [Starting Capture]
Apr 10 06:09:02 wdshss zmdc[24341]: INF ['zmc -d /dev/video3' started at 06/04/10 06:09:02]
Apr 10 06:09:02 wdshss zmc_dvideo3[24341]: INF [Debug Level = 0, Debug Log = <none>]
Apr 10 06:09:02 wdshss zmdc[24314]: INF ['zmc -d /dev/video3' starting at 06/04/10 06:09:02, pid = 24341]
Apr 10 06:09:02 wdshss zmc_dvideo3[24341]: INF [Starting Capture]
Apr 10 06:09:02 wdshss zmdc[24345]: INF ['zma -m 2' started at 06/04/10 06:09:02]
Apr 10 06:09:02 wdshss zmdc[24314]: INF ['zma -m 2' starting at 06/04/10 06:09:02, pid = 24345]
Apr 10 06:09:02 wdshss zma_m2[24345]: INF [Debug Level = 0, Debug Log = <none>]
Apr 10 06:09:02 wdshss zma_m2[24345]: INF [In mode 3/1, warming up]
Apr 10 06:09:03 wdshss zmdc[24314]: INF ['zmfilter.pl' starting at 06/04/10 06:09:03, pid = 24349]
Apr 10 06:09:03 wdshss zmdc[24349]: INF ['zmfilter.pl' started at 06/04/10 06:09:03]
Apr 10 06:09:03 wdshss zmdc[24353]: INF ['zmaudit.pl -c' started at 06/04/10 06:09:03]
Apr 10 06:09:03 wdshss zmdc[24314]: INF ['zmaudit.pl -c' starting at 06/04/10 06:09:03, pid = 24353]
Apr 10 06:09:04 wdshss zmdc[24314]: INF ['zmwatch.pl' starting at 06/04/10 06:09:04, pid = 24357]
Apr 10 06:09:04 wdshss zmdc[24357]: INF ['zmwatch.pl' started at 06/04/10 06:09:04]
Apr 10 06:09:04 wdshss zmwatch[24357]: INF [Watchdog starting]
Apr 10 06:09:04 wdshss zmwatch[24357]: INF [Watchdog pausing for 30 seconds]
Apr 10 06:09:04 wdshss zmfilter[24349]: INF [Scanning for events]
Apr 10 06:09:04 wdshss zmdc[24363]: INF ['zmupdate.pl -c' started at 06/04/10 06:09:04]
Apr 10 06:09:04 wdshss zmdc[24314]: INF ['zmupdate.pl -c' starting at 06/04/10 06:09:04, pid = 24363]
Apr 10 06:09:05 wdshss Update agent starting at 06/04/10 06:09:05
Apr 10 06:09:35 wdshss zmc_dvideo0[24337]: INF [Test: 1000 - Capturing at 30.30 fps]
Apr 10 06:09:36 wdshss zmc_dvideo3[24341]: INF [Test2: 1000 - Capturing at 29.41 fps]
Apr 10 06:09:36 wdshss zma_m2[24345]: INF [Test2: 1000 - Processing at 29.41 fps]
Apr 10 06:10:09 wdshss zmc_dvideo0[24337]: INF [Test: 2000 - Capturing at 29.41 fps]
Apr 10 06:10:09 wdshss zmc_dvideo3[24341]: INF [Test2: 2000 - Capturing at 30.30 fps]
Apr 10 06:10:09 wdshss zma_m2[24345]: INF [Test2: 2000 - Processing at 30.30 fps]
Apr 10 06:10:21 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
Apr 10 06:10:22 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
Apr 10 06:10:23 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
Apr 10 06:10:24 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
Apr 10 06:10:25 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
Apr 10 06:10:26 wdshss zms[24450]: ERR [Bogus scale factor 0 found]
got my eye on you!
sick347
Post by sick347 »
Here is more from a second try for an event triggered by motion.
Apr 10 20:48:17 wdshss zmc_dvideo3[26866]: INF [Test2: 127000 - Capturing at 30.30 fps]
Apr 10 20:48:17 wdshss zma_m2[26877]: INF [Test2: 127000 - Processing at 30.30 fps]
Apr 10 20:48:18 wdshss zmc_dvideo0[24337]: INF [Test: 1581000 - Capturing at 30.30 fps]
Apr 10 20:48:50 wdshss zmc_dvideo3[26866]: INF [Test2: 128000 - Capturing at 30.30 fps]
Apr 10 20:48:51 wdshss zma_m2[26877]: INF [Test2: 128000 - Processing at 29.41 fps]
Apr 10 20:48:52 wdshss zmc_dvideo0[24337]: INF [Test: 1582000 - Capturing at 29.41 fps]
Apr 10 20:49:14 wdshss zma_m2[26877]: INF [Test2: 128714 - Gone into alarm state]
Apr 10 20:49:14 wdshss zma_m2[26877]: ERR [Can't insert frames: Duplicate entry '13806' for key 1]
Apr 10 20:49:14 wdshss zmdc[24314]: ERR ['zma -m 2' crashed, exit status 38]
Apr 10 20:49:15 wdshss zmdc[24314]: INF [Starting pending process, zma -m 2]
Apr 10 20:49:15 wdshss zmdc[27261]: INF ['zma -m 2' started at 06/04/10 20:49:14]
Apr 10 20:49:15 wdshss zmdc[24314]: INF ['zma -m 2' starting at 06/04/10 20:49:14, pid = 27261]
Apr 10 20:49:14 wdshss zma_m2[27261]: INF [Debug Level = 0, Debug Log = <none>]
Apr 10 20:49:14 wdshss zma_m2[27261]: INF [In mode 3/1, warming up]
Apr 10 20:49:16 wdshss zma_m2[27261]: INF [Test2: 063 - Gone into alarm state]
Apr 10 20:49:17 wdshss zma_m2[27261]: ERR [Can't insert frames: Duplicate entry '13806' for key 1]
Apr 10 20:49:17 wdshss zmdc[24314]: ERR ['zma -m 2' crashed, exit status 38]
Apr 10 20:49:18 wdshss zmc_dvideo3[26866]: WAR [Buffer overrun at index 23, slow down capture, speed up analysis or increase ring buffer size]
Apr 10 20:49:19 wdshss zmc_dvideo3[26866]: WAR [Buffer overrun at index 23, slow down capture, speed up analysis or increase ring buffer size]
Apr 10 20:49:20 wdshss zmc_dvideo3[26866]: WAR [Buffer overrun at index 23, slow down capture, speed up analysis or increase ring buffer size]
Apr 10 20:49:22 wdshss zmdc[24314]: INF [Starting pending process, zma -m 2]
Apr 10 20:49:22 wdshss zmdc[27278]: INF ['zma -m 2' started at 06/04/10 20:49:22]
Apr 10 20:49:22 wdshss zmdc[24314]: INF ['zma -m 2' starting at 06/04/10 20:49:22, pid = 27278]
Apr 10 20:49:22 wdshss zma_m2[27278]: INF [Debug Level = 0, Debug Log = <none>]
Apr 10 20:49:22 wdshss zma_m2[27278]: INF [In mode 3/1, warming up]
Apr 10 20:49:24 wdshss zmc_dvideo3[26866]: INF [Test2: 129000 - Capturing at 29.41 fps]
Apr 10 20:49:25 wdshss zmc_dvideo0[24337]: INF [Test: 1583000 - Capturing at 30.30 fps]
Apr 10 20:49:55 wdshss zma_m2[27278]: INF [Test2: 1000 - Processing at 30.30 fps]
Apr 10 20:49:57 wdshss zmc_dvideo3[26866]: INF [Test2: 130000 - Capturing at 30.30 fps]
Apr 10 20:49:58 wdshss zmc_dvideo0[24337]: INF [Test: 1584000 - Capturing at 30.30 fps]
Apr 10 20:50:28 wdshss zma_m2[27278]: INF [Test2: 2000 - Processing at 30.30 fps]
got my eye on you!
jameswilson
Post by jameswilson »
I would limit your max fps per cam to say 5 as 120 fps req some serious hardware
James Wilson
sick347
Post by sick347 »
I checked my MAX FPS and it is 0.0.
I wonder if I have messed-up any of these values:
Image Buffer Size (frames) 30
Warmup Frames 25
Pre Event Image Buffer 10
Post Event Image Buffer 10
Alarm Frame Count 1
-frank
got my eye on you!
zoneminder
Site Admin
It does look in a bit of a state. The duplicate key errors are a bit worrying as they imply there is something wrong with the db. Have you tried doing a mysqlcheck on it?
Phil
sick347
Post by sick347 »
ok looks like there were issues as you suspected.
I hope this was a one-time deal. Otherwise, I'm not sure how it happened so I cannot be sure to not do it again (if I caused this problem).
zm.Config
warning : 3 clients are using or haven't closed the table properly
status : OK
zm.Controls
warning : 1 client is using or hasn't closed the table properly
status : OK
zm.Events
warning : 2 clients are using or haven't closed the table properly
warning : Size of indexfile is: 39936 Should be: 33792
warning : Size of datafile is: 32016 Should be: 27244
warning : Found 26707 record-data and 537 unused data and 0 deleted-data
warning : Total 27244, Should be: 32016
status : OK
zm.Filters
status : OK
zm.Frames
warning : Size of indexfile is: 711680 Should be: 533504
warning : Size of datafile is: 549540 Should be: 408480
error : Found 13715 keys of 13616
error : Corrupt
zm.Groups OK
zm.MonitorPresets
status : OK
zm.Monitors
status : OK
zm.States OK
zm.Stats
warning : Table is marked as crashed
warning : Size of indexfile is: 165888 Should be: 162816
warning : Size of datafile is: 320705 Should be: 317226
error : Found 5922 keys of 5931
error : Corrupt
zm.TriggersX10 OK
zm.Users
status : OK
zm.ZonePresets
status : OK
zm.Zones
status : OK
frank@wdshss:/var/log>
thanks
-frank
got my eye on you!
sick347
Post by sick347 »
ok now after I ran the mysqlcheck the first time I tested ZM again and still get the same results (no events captured as seen by ZM). However I do notice that the events directory is filling with events, the DB still has ERRORS, see below:
zm.Config OK
zm.Controls OK
zm.Events
warning : Size of datafile is: 32016 Should be: 27712
error : Wrong bytesec: 111-116-105 at linkstart: 27712
error : Corrupt
zm.Filters OK
zm.Frames
error : Corrupt
zm.Groups OK
zm.MonitorPresets OK
zm.Monitors OK
zm.States OK
zm.Stats
error : Corrupt
zm.TriggersX10 OK
zm.Users OK
zm.ZonePresets OK
zm.Zones OK
got my eye on you!
sick347
Post by sick347 »
oh boy,
now after I have STOPPED ZM I get this IN my ZM console webpage:
Can't open file: 'Events.MYI' (errno: 145)
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /srv/www/htdocs/zoneminder/zm_html_view_console.php on line 85
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /srv/www/htdocs/zoneminder/zm_html_view_console.php on line 86
this seems to be in a downward spiral ....HELP!!!
-frank
got my eye on you!
jameswilson
it looks like you have something seriously wrong with you db maybe delete it all and start again? also max fps of 0 means no maximum put a number in here at least to begin with. eg 5. Also you might want to check the disks are ok fsck
James Wilson
acrid
Post by acrid »
it looks like mysqlcheck didn't fix anything...
try
mysqlcheck -r
otherwise it won't repair.
$> man woman
$> Segmentation fault (core dumped)
sick347
Post by sick347 »
acrid wrote:it looks like mysqlcheck didn't fix anything...
try
mysqlcheck -r
EXCELLENT CALL acrid!!!
check it out:
frank@wdshss:~> mysqlcheck -u root -p -r --all-databases
Enter password:
mysql.columns_priv OK
mysql.db OK
mysql.func OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.host OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.user OK
zm.Config OK
zm.Controls OK
zm.Events
info : Wrong bytesec: 111-116-105 at 27712; Skipped
warning : Duplicate key for record at 27616 against record at 27044
warning : Duplicate key for record at 27692 against record at 27096
warning : Duplicate key for record at 27768 against record at 27148
warning : Duplicate key for record at 27844 against record at 27200
warning : Duplicate key for record at 27920 against record at 27252
warning : Duplicate key for record at 27996 against record at 27304
warning : Duplicate key for record at 28072 against record at 27356
warning : Duplicate key for record at 28148 against record at 27408
warning : Duplicate key for record at 28224 against record at 27460
warning : Duplicate key for record at 28300 against record at 27512
warning : Duplicate key for record at 28376 against record at 27564
warning : Number of rows changed from 375 to 420
status : OK
zm.Filters OK
zm.Frames
warning : Number of rows changed from 13616 to 18318
status : OK
zm.Groups OK
zm.Monitors OK
zm.States OK
zm.Stats
warning : Number of rows changed from 5931 to 6002
status : OK
zm.TriggersX10 OK
zm.Users OK
zm.ZonePresets OK
zm.Zones OK
frank@wdshss:~>
Looks better now. Only question is HOW did it get this way? The only change I made was to reassign the cameras and all eck broke lose. Could that have been the reason?
thanks
-frank
got my eye on you!
maclellan
Post by maclellan »
In my experience I aso had this error. My personal recommendation is to try converting your database over to INNODB tables. Researching the web I found this to be faster for larger tables (as events grow) and much more reliable.
-scott
