I set up monitors. I went to update from 1.19.5 to the more recent 1.22.0 version. I did not realize there was a update script so I tried to uninstall, and remove all things connected to zm that i could see. Then i reinstalled using 1.22.0. All seems good to go. I can get video using tv time. Only problem with video at the moment is 2 out of my 4 channels work. Only 1 and 3 work. (based on 0 - 3 scale). Well besides this problem which i will work out as i look more into it, I have a problem getting these monitors working in ZM.
I got to the web admin and i set up the monitors as follows.
Monitor1 Monitor /dev/video0 (1)
Monitor2 Monitor /dev/video0 (3)
When I open up the ZM for the monitor I get one of the 2 following. On monitor 1 i set a size from x & y. I open it up and there is a broken image. On monitor2 it shows up as a very small window, and i am guessing a broken image as well.
I am not sure what i need to check to solve this problem though, but I am open to try anything that is suggested.
Thanks for all the help so far, and hoping to get this excellent program up and running again.
