Hi
i got a BT878 card with 1 cip/4 ins - Provideo PV143
lspci :
(relevant part)
02:04.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:04.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
dmesg :
(relevant part)
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:04.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
bttv0: Bt878 (rev 17) at 0000:02:04.0, irq: 11, latency: 66, mmio: 0x40c00000
bttv0: detected: Provideo PV143A [card=105], PCI subsystem ID is aa00:1430
bttv0: using: ProVideo PV143 [card=105,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
zm is working but images are like this:
anyone has any ideea whats wrong with this ?
Thank you all.
Bad card ????
your not feeding ntsc into a pal input or vice versa? And what color palle you tried
James Wilson
- diablo43000
tryed all Capture Palettes but it seems thats not the problem
about feeding pal in to ntsc or viceversa: they are bouth pal
so thats not my problem
ty for ur answer
output of
any other ideeas ?
it looks to me like its a frquency problem (just like a monitor witch doesent support the feded frequency) can this be a cause ???
ty for ur answer
output of
eye1 ~# zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video (ProVideo PV143)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 528
Height: 432
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 40000
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
- diablo43000
One thing i would try is research your card and check its being detected properly, ie if its autodetecting as a card=105 are you sure its a 105. Have you tried the usual 77?
Just my 2 pence mate and getting cards to work can be a 8astard!
James Wilson
Try a few standard monitor resolutions. That is 640x480, 480x360, 320x240. Be sure to set all the monitor resolutions to the same resolution. Dont forget to restart zoneminder after making changes. Try varying the buffers say ... 20,5,10,10,1. Also check the shared memory max in sysctl.conf to approx 3/4 total memory .. ie kernel.shmmax=384000000 for 512K.
-scott
-scott
