Conexant B878A
yeah that is odd as thats a single chip card
James Wilson
Video still not working, it has been 2 days now and i still do not know what to do. I have done the following.
took out the tuner part from /etc/modprobe.conf
When i do this i get a blank black video. If i remove the camera it goes to blue.
This error keeps coming up not matter what I do to the tuner part of the modprobe.conf
Any help? Thanks!
# tvtime
Running tvtime 1.0.1.
Reading configuration from /usr/local/etc/tvtime/tvtime.xml
Reading configuration from /root/.tvtime/tvtime.xml
videoinput: Can't get tuner info: Invalid argument
Any help? Thanks!
If its going blue then tvtime can see the card ok, have you checked your settings in tv time ie tv standard and resolution etc.
James Wilson
I set it to NTSC which seems normal. I tried it on a PAL setting and it did the lower half in a flicker, which is what i notice when i try and play PAL on a NTSC dvd player.
So as far as I can see the video seems right, but it is still complaining about the tuner info or whatever, and I am not sure what to do for that. This happens when I try and switch video composites. It will say that the tuner info could not be read, which is why I think it has to be the tuner.
Ok now almost a month later and fiddling like crazy I have not been table to get it to work. I currently do not have network on the linux box but will shortly, so any outputs will have to wait.
I currently have a blue screen for all 4 inputs. I insert the 1 camera into the slot and see it works and I get a black screen. When i remove it it goes back to blue. From what I have been reading is that blue means the camera is ready for input. I am pretty sure the camera's work as they were before this came up. Could there be something else coming up that I do not see?
I am also continuing to get these errors.
Any help will be appreciated.
# tvtime
If this is the card I believe it to be, (same picture) it was sold on e-bay for $9.99 US.
These are shipped out of Texas. I have also seen the cards in the UK by seller Owlight, ( I think).
I ordered this card and it did work with my linux box.Chanel 0 workled fine and one other channel worked for a while. I never got all four channels working. The longer I used the card(two weeks) the more channels I seem to lose. Thought it might be BNC connectors so I changed them, no help. I finally hooked up my 4 cameras to a multiplexer on and old vcr system and all worked...So I surmize; I got what I paid for. The experiance was valuabe and I didn't lose my shirt trying out the DVR I put together.
Now if I could get the motion detection configured properly I would be fine...but thats another story.
Hope your luck is better than mine..I decided to cut my losses and buy a new card...for more than 9.99 US.
