I've got about 5 systems using geovision cards/software but I'm quite unhappy with their operation and closed nature. Plus they're windows only. If they had linux versions, I'd probably put up with their crappy designs.
As it is, i've been hoping zm would be my way out of gv hell. however, the 4 port no-name korean card, and the 4 port kodicom 4400 i recently bought cant be made to work (by me at least) on gentoo, debian sarge 3.0 or 3.1 or mandrake. i've tried the live cd as well. I know the first card works because i used it before i dumped it for the geoview systems. argh. just venting..
now for my question. Does anyone know anything about vnc recording and zoneminder? I've found a few matches on google re: vncrec and i'll be looking into that, but has anyone tried to or wanted to integrate that as a zoneminder stream?
The use I have in mind is loss prevention in a retail setting. i have a small business that watches the register from above, but the resolution and frame rate isn't good enough to see what is being put into the POS system. VNC viewer can show that, but it would be really cool to have it syncronised with the other camera shots that zoneminder is saving.
mind you, i haven't actaully gotten zm to work yet due to hw problems but i'm just putting this question out there. maybe there are other there with the same use in mind, that would like to discuss their setups and how it's working out for them.
Thanks,
Ed
