Other PAL formats ?
wimg
Other PAL formats ?
Post by wimg »
I'm using an Intel Create & Share camera on /dev/video0 with Zoneminder. However, in xawtv I have to set it up as PAL-M, but I can't do that in Zoneminder, which causes the image to split in half. Is there a way to set it to PAL-M ?
Wim
fernando
Re: Other PAL formats ?
Post by fernando »
you may trie 0 to 9 or more in device format. iam shure you will find it.
