thank you very much for this nice software. It is running great but I have small problem to set up correct camera resolutions.
I use a Ituner Spectra 8 - Video Card and some different cameras. Problem is to set higher resolutions than 320x240. In different software (for example "Motion") I can use 720x576 PAL resolution without changing anything. I use debian etch with self compiled but very close to standard debian 2.6.15 Kernel.
In zoneminder is everything higher than 320x240 not possible. If I use zmu to query my video device it will say me that max resolution is 924x576. But what meens windows attributes with 320x240 or how can I change this.
Many greetings
cactus.
zmu-query
cactus@video01:~$ zmu -q -v -d /dev/video0 -U admin -P admin
Video Capabilities
Name: BT878 video (ProVideo PV150)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 2
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 1 - Linear greyscale
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
cactus@video01:~$
