How Delete events
germandms
How Delete events
Post by germandms »
Hi
How can delete all event....
thk
cordel
Post by cordel »
The easiest way if you have a lot of events is create a filter that selects all the events and have it delete them. You can try clicking the event total from the console, click show all in the results window, then check all box, and delete as well. Just make sure you have thumbs turned off or it might take a while.
Regards,
Corey
