1.22.1
NiGlim
Post by NiGlim »
Hi all.
When I´m adding a new monitor with presets type Axis IP, 320x240, mjpeg I got in the parent window:
"Unknown column 'AlarmMaxFPS' in 'field list'"
Do I do somthing wrong or is it a bug?
I have tested with other presets, it´s the same
maciekc
Post by maciekc »
Maybe you didn't updated your database when upgrading. Did you use zmupdate.pl?
NiGlim
Post by NiGlim »
zmupdate.pl –version=<from version> [--user=<database user> --pass=<database password>]
I shall do thr update one more time to see if something strange happens...
Thanks.
