Missing zone preset if upgraded.
rdmelin
Post by rdmelin »
Hi Phil,
1.22.1 is looking great. :)
I found one issue if upgrading from 1.22.0 which had 5 zone presets. 1.22.1 has 6 and the 6th is not added by update sql. So 'Best, high sensitivity' is missing after upgrade.
INSERT INTO ZonePresets VALUES (6,'Best, high sensitivity','Active','Percent','Blobs',20,NULL,8,NULL,3,3,6,NULL,5,NULL,1,NULL);
Should take care of it.
zoneminder
Site Admin
Post by zoneminder »
Thanks for spotting this Ross. I have added it to the buglist and will add it into the next release which I will try and get out in the next couple of weeks I think due to the missing language token.
Phil
